what I found in my 18" 76 rogers subfloor
Results 1 to 13 of 13
    Maple Ridge B.C. Canada
    Default what I found in my 18" 76 rogers subfloor
    So I cut a 6" hole in my subfloor to see what was in there. After sitting in my heated shop since October I found 12 pounds of brown stinky water. Who knows how much was there at the end of the boating season. I opened up the bow last year and pulled out a bunch of water and foam pellets. Just sharin what I've learned with other rogers owners , kind of a boat diet ! bet I've lost 30lbs between the two compartments.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    That might be factory water. Maybe it can be sold to someone else.
    QE 439 Twin Turbo
    Senior Member buckjohnson's Avatar
    Aug 2009
    Biola CA
    We'll take any water we can get in in the Valley!
    Senior Member almost busted's Avatar
    Sep 2012
    MN
    bummer i got the same rig bet they put that factory water in mine too !!! just did new carpet 2 summers ago. didnt seem to look rottin or wet anywere no good !!!
    Jan 2013
    Magic Mountain CA
    Quote Originally Posted by almost busted View Post
    Mine had it as well. Floor was solid with no indication of water.
    I drilled a hole in the piece of plywood right in front of the engine then opened the hole up by hand so as not to damage the hull. Water started flowing. When I pulled the floor top was pretty solid and underneath was pretty bad.
    Always a good idea to know the condition of the basement on these boats with subfloors this was in out Daytona V bottom project, debris and saturated floor weighed a ton..
    Jan 2012
    St. Louis, MO
    LOL! Well....you have me wondering Tom. Unless the boat was on the ground, how DID the worm(s) get in there??? Robin dropped his lunch?
    Sep 2012
    MN
    Quote Originally Posted by 74Bonneville View Post
    well i guess i know whats next to fix now damit !! bummer what did you use to cut the sub floor out so you didnt get into the bottom of the hull?
    Jun 2012
    Why dont we jetboaters put access holes in the sub floors to do a clean out n wipedown after use? Ive been thinking about doing 2 and putting in cup holders as the plug per se so after a day on the river unplug, wrap something (havent figured out what yet) and wipe down under the floor.
    my fix, storage too!
    Senior Member desrtrat256's Avatar
    San Diego, CA
    Quote Originally Posted by rogerroost View Post
    Snap On Socks?
    Sep 2012
    MN
    Quote Originally Posted by desrtrat256 View Post
    Snap On Socks?
    maybe got that idea from watchin boarder wars. quick easy fix for now just to get by till a guys got time to rip it in half looks like it will work for now . to soon to boating to start makin a mess kinda a big project for someone not doin it all the time. good idea anyway for a temp fix
    good eye on the socks. why do they both have "L" on them ?
    I am not really thinking this is a "temp" fix . The wood seem ok, not soft at all. throw my carpet over the cover and call it done and go boating!
