Lettering
Results 1 to 14 of 14
Lettering
    Sep 2011
    Los Angeles
    Default Lettering
    Who do you guys use for lettering? I need to remove these Texas numbers and put on the new CF numbers and name
    Somebody remotely close to Rancho Cucamonga
    Jul 2013
    custom member raped southwind's Avatar
    so-cal
    Do you want them painted or vinyl?
    As for paint there is a guy who GT used to use out of Upland area i can get you his number , If you want vinyl shoot me over what you need and ill cut them tonight
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    Call Brian Wilcox. Lefty's Pinstriping @ 909-528-7226.
    He's in Yucaipa. He used to be on PB as well, I think his name was BajaDad.
    Guy does great work.
    Aug 2013
    yucca valley ca
    X2 on leftys ....does amazing work can't wait for my hull to be done he is definitely getting my business
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by nick View Post
    Lefty's is the man! does great work for sure.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Apr 2014
    What does it usually cost for CF numbers to be painted on?
    Sep 2011
    Los Angeles
    I'm looking for painted. But I need someone who can take off the old numbers too. Does Lefty's do that?
    Apr 2014
    Quote Originally Posted by larryfknrocks View Post
    I took my painted numbers off myself. Pretty easy. Get yourself some 400 and 1500 wet. Just take your time. Start with the 400 and carefully sand most of the lettering off. Keep it wet. Then hit it with the 1500 to get the area smoother and get any leftover lettering. Finish the area off with a compound. When I was done you couldn't even tell anything was there. I went with vinyl lettering but would like to have them painted eventually.
    San Diego, CA
    Bob Thompson, Team Thompson. Great guy, great work! Out of havasu, makes trips to Cali all the time to do work. Call him, he will come to you. 909 226-6188
    Boat 405.
    Feb 2009
    MANTECA
    I had my cf numbers painted on years ago up here in nor cal. There was some painting on the back of the transom that I wanted removed I asked the guy if he could remove it so he sprayed easy off on it. The paint came right off in a matter of seconds and the gel coat was not affected. I don't think I would try this on a painted boat it might take all the paint off.
    X'3 on leftys pinstriping!!!!!
    Mar 2010
    Clarksville, TN
    Easy off is the shit, comes off like butter. Just don't let it set to long, work in small areas.
    Sep 2011
    Los Angeles
    With my luck I'll peel 3 layers of paint off. I'll let a pro do it
    Larry. Look at leftys instagram, does a ton of lettering be hand. Think it's leftypinstriping. He is mobile too. I plan to have him do my new boat.
