Running out of water
Results 1 to 14 of 16
    Senior Member k5-cj5's Avatar
    Apr 2014
    Kuna, Idaho
    Default Running out of water
    I have read a lot of conflicting information about running a jet out of water. Is it acceptable for the boat to run for a few seconds without water to the pump? If there is a hose spraying thought the intake of the pump is that sufficient for short amount of run times? I know the engine needs water but separate from the pump. Thanks.
    seattle
    Fire it up! I have been running my boats on the trailer for decades...I have never seen any problems...I raced my boat last year...I had to warm it up before every race...(pump spinning)...over winter i wanted to add a shoe and a ride plate...pulled the pump all apart and seen no problems!!! in anycase there should be alot of people telling you not to do it...
    Just run it for a minute or less and you will be fine!!!
    75 Eliminator
    Quote Originally Posted by k5-cj5 View Post
    Use the search function on here for more threads ,information and differing opinions on this subject than you can stand , ours opinion is still no
    Apr 2014
    Kuna, Idaho
    Pk thanks for the info...Ill do some searching!
    Maple Ridge B.C. Canada
    I think the key is to understand the risks, then make your own choice. The risk is burning the packing seal at the input shaft, and having damage from dirt or debris between the impellor and wear ring , and deflection in the pump shaft from reving it unloaded. I'll run mine for a short time with no water.
    May 2014
    I would suggest hooking up a garden hose to the cold water intake. It is usually pretty easy. Also, loosen off your pump packing nuts. Lastly, I take off my bowl and impellor. This prevents the impellor from rubbing against the wear ring, it could cause a lot of wear to the impellor and the wear ring because of silt in the pump. Hope this helps.
    so you would suggest to this guy to run his boat
    with the pump shaft spinning without any support at the end of the shaft.
    Surprise, AZ
    Remove the bowl and impeller? Seems like a ton off work to run it. Disconnect the drive line, it's 4 bolts.
    Sent from my VS980 4G using Tapatalk
    Quote Originally Posted by 67weiman View Post
    Nope, that's too simple.
    It may be the best way, but it's just too simple.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Hook a water hose to the water exit and run it backward through the engine and pump. Even have someone hold the hose up against it.
    If you have descent water pressure just enema the pump. Water will make it to the front. If it's running out the intake its getting the wear ring
    QE 439 Twin Turbo
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    Just curious, but do any of you give your pump a "quick spin" (a second or 2) AFTER a day on the lake to push any remaining water out of the pump bowl? Good or Bad Idea?
    Mar 2010
    Clarksville, TN
    Do not do it !!!!!! Several people will say its fine but it is not a good thing to do. JMO
    Apr 2014
    Kuna, Idaho
    Well, I think ill just stay clear of running it out of water. Not worth the risk, the lake is only a 15 min drive when its full. Thanks for all the input everyone.
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by SNiC View Post
    A lot of it drains out goin up the ramp. It gets pretty cold here in the winter and I like to make sure alittle antifreeze gets to the bowl for winter storage to mix with the small amount of water that does set in the bowl.
