impeller help !!
Results 1 to 3 of 3
impeller help !!
    Jan 2013
    Default impeller help !!
    I have a A hi-helix but the rpm I want to run is right where a B hi-helix is, I am debating whether to just buy a B or cut my A down, if the A was cut down to a B would they be the same ? or would I be better off buying a B.
    Mar 2010
    Clarksville, TN
    You can trim it to where you need the RPMs to be.
    Iuka, Mississippi 38852
    It would be the same. I`ve done it before. You might try an AB first as you can`t add if you go too far.
