Jet boat RPM Problem
Results 1 to 14 of 18
    May 2014
    Default Jet boat RPM Problem
    I recently bought a 1979 Crusader Tunnel Hull with a Berkley 12JG "B" cut impeller. Engine runs great but I can only turn 5000 RPMs. The engine only has about 15 hours on it and has amazing amount of power. I can floor it and it immediately hits 5,000 and just stays there. I was told the way this engine was built I shouldn't have any problems turning 6,000 RPMs. The guy I bought the boat from had a mild 454 in the boat before he had this one built and he said that the old enigne turned 5,900 rpms. I am thinking it might be a fuel problem but not for sure. I would appreciate any help. Thank you.
    The engine is
    GM 454, bored .03 over
    Pro Comp Aluminum Heads;
    • Intake Port - 320cc (rectangle)
    • Combustion Chamber - 115cc
    • Intake Valve Size - 2.25"
    • Exhuast Valve Size - 1.88"
    • Valve Steam Dia. - 11/32"
    • Intake Port Size - 1.8" W x 1.95" T
    • Exhaust Port Size - 1.9" x 1.65" T
    • Spring Pocket Dia. - 1.730
    • Valve Material Stainless Steel
    • Valve Length - +.250" intake, +.100 exhaust
    • Valve spring Dia. - 1.525", Single
    • Spring Pressure closed - 140lbs @ 1.900"
    • Spring Pressure open - 380lbs @ 1.200"
    Camshaft
    • Herbert Racing
    • Adv Dur I 316 E 332
    • @ .05 I 244 E 254
    • Lift .596 .625
    • Valve Lash I 002 E .024
    • @.05 I open 29 closed 72
    • E open 74 closed 35
    Forged Pistons (10.5:1)
    Forged GM Crankshaft
    Roller rockers
    Pro Comp H-Beam Connecting rods
    Main and head stud kit
    6AL MSD Igniton
    Tunnel Ram intake with two Holley 660 Carbs.
    Where does this engine make power and how much per the builder @ 6K ?, what jet and what impeller & what altitude , is the jet fresh ?
    May 2014
    To be honest I don't honestly know a lot about the pump just that it is a few years old and is a berkley 12JG with a stainless B cup impeller, stage 3 loader grate, ride plate, wedge, droop snoot and diverter. It has tons of power but when From a stop it shoots up to 5000 and wont turn any more RPMs. I am new on jet boats, so I really don't know anything about them.
    the jet with B impeller @ 5K is suggesting your making a bit under 400 HP , the motor build description sounds like it should make quite a bit more ..
    4900 361.02
    5000 383.58
    5100 407.05
    May 2014
    I have built many truck engines but I haven't messed with any kind of engine like this. When I'm and full throttle the engine seems to be producing the same amount of power. The carburetor secondaries are 1 to 1 as for as I know. I am running about 4 psi on the fuel too.
    Senior Member BGMAN's Avatar
    You didn't mention what exhaust you have on the engine. headers? logs? What about your ignition timing? Fuel pressure at 4psi seems a little on the low side. I would bump it up to the 6-8 range if possible.
    May 2014
    It has Bassett Headers and the timing is at 34 degrees. It does have a fuel regulator. I just wanted to make sure it was okay to bump it up a little.
    Quote Originally Posted by awhite10 View Post
    Assuming its running a Holley, 4 is not enough need 6 to 7 , be interesting to see the cam card from Herbert (rpm range)
    Try bumping up the timing a few degrees, maybe try 36 total. 7 psi on the fuel seems to be what most everyone tries to run. I have seen some guys get away with 9 to try and fix a off idle stumble. I know this is going to sound stupid, but try turning your scoop backwards and see if you pull more rpm. There was a guy a while back that was having a similar rpm issue and figured out the scoop was disrupting the air flow to the carbs, too much ramming.
    If nothing improves, then you need to start looking a the engines vitals. Leak down, compression test, etc. It's also possible that the motor doesn't have what the previous owner has told you and you really have a 385-400 hp motor. It's also possible the pump doesn't have a B cut impeller.
    Lots of variables and a big mystery when buying used.
    May 2014
    I actually have receipts to everything for the engine, so I do believe him on the engine. The pump I do not have any kind of documentation. How can you tell what size of impeller that I have? Ill try to post a video to show how it runs.
    Senior Member Chuck Wagon's Avatar
    Palm Desert
    5000 rpm pill in the MSD?
    May 2014
    That was one of the first things I checked and it has a 6500 RPM limiter in it.
    Quote Originally Posted by Chuck Wagon View Post
    That's what I would check first!, or quite possibly it has bigger cut impeller then a B, especially if it pulls real hard out of the hole then flattens out, or its just a 400hp motor.
    4900 361.02
    5000 383.58
    5100 407.05
    Tom, what's the estimated hp rating @5k rpm on a A or AA impeller?
