fixable?>
Results 1 to 14 of 20
fixable?>
    Senior Member beerngasoline86's Avatar
    hacienda heights ca
    Default fixable?>
    so i was heading out to the river last weekend and i had a leaf spring break on the boat trailer and in result ripped the truck and boat of the 40 hwy just outta lulow in a 15 ft revign..end results below...
    General Contractor Jetdriver's Avatar
    Burbank
    It can be fixed.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    It most definitly can be fixed, to the point that no one could tell that there was any repair even made!
    hacienda heights ca
    anybody up for the job? i will give it to you cheap
    Member Richcraft's Avatar
    alta loma ca
    Quote Originally Posted by beerngasoline86 View Post
    are you looking to get it fixed or you sellin
    hacienda heights ca
    probably sale it
    alta loma ca
    how much$$$$
    hacienda heights ca
    not sure what a tunnel hul;l with a holw in it is worth
    hacienda heights ca
    $1000..
    Las Vegas, Nv
    What brand hull is it? That hole is a relativly easy fix....Hal
    Silverdale, Washington
    Come on Hal, you gotta finish the other one first. Besides, I'm looking for a new project.
    hacienda heights ca
    its a texas
    are you looking to replace it with same tunnel boat ? or better yet what comes with it ? bob
    hacienda heights ca
    just the hull maybe the front seats and stringer rails
