IHBA Battery switch
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 45
IHBA Battery switch
    Senior Member ULTRA 23's Avatar
    Corona, CA
    Default IHBA Battery switch
    I need to install a battery switch in my boat for the finals. Can some of you guys post pictures of yours so I have some ideas where to mount it. I would like to see pictures of guys who have run IHBA this year and how critical are they in tech about this switch placement.
    John D
    INLAND ULTRA CUSTOM BOATS
    Corona, CA
    951-734-6000
    Ultraboats.com
    Senior Member Pattymelt18's Avatar
    John mounted a bracket off my existing battery box since its in the back of the boat then just ran the wire up to that i asked prigmore and this is the way he said his is done so i just copied him sorry no pics though.
    Mohave Valley/Quartzsite
    Just to give you a couple ideas. I mounted mine off the seat brace which puts it just above the battery. I know they want it on the positive side of the battery but I installed mine on the negative side. In theory it works EXACTLY the same. It's also a Flaming River switch, very nice but a little expensive. I have been to a few events with this setup!!
Name:	10-19 Bakersfield Deck Picture 2.jpg
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Senior Member bp298's Avatar
    LHC
    john, i wanted mine as close to the battery as possible, so that's where i installed it. i also have the flaming river switch - it comes with a little bracket, so i just bolted that to the battery hold down...
    B1 Racing cs19's Avatar
    what does this thing need to shut off? fuel and ignition or just kill the ignition?
    Its so lame!!!!!!
    B1Racing.net
    Corona, CA
    Thanks Vince and BP
    John D
    Corona, CA
    951-734-6000
    Ultraboats.com
    Its so lame!!!!!!
    Chris, I have mine wired where it shuts of the ground to the battery so basically everything!! And to be honest I was against it also but man it's nice being able to kill the whole system with a single switch. I use to take the battery on and off after each run. I don't mind it so much now!!
    Quote Originally Posted by ULTRA 23 View Post
    Thanks Vince and BP
    Anytime!!! Not sure if it helped though!! You jetboat guys like doing things different..
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    im just curious what IHBA wants, just ignition kill or both fuel and ignition?
    B1Racing.net
    Senior Member Here Comes Whitey's Avatar
    Budweiser rd hit squad
    Mine kills everything. i assume they want both in case of fire it would kill the pumps. Its stupid cause if there was a fire they wouldn"t be sticking there heads in the back of the boat to turn the batt switch.
    Quote Originally Posted by Here Comes Whitey View Post
    exactly. I guess my question is what do they check for in tech?
    B1Racing.net
    It needs to be a main battery disconnect switch. Whether you wire it on the positive side or negative side it needs to kill all power to everything. Similar to NHRA.
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    Senior Member BGMAN's Avatar
    In NHRA it also has to kill the motor when its running, so you have to loop the alt wire in there too. Not sure if you guys are running them or not, so don't forget about that.
    Quote Originally Posted by BGMAN View Post
    Good point!!!
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    Cantard 71hallett's Avatar
    snow bank
    In nhra/ihra it has to shut everything off. I have seen this save a car twice now. Both times they were electical fires. Ever try to put one of those out when you have about 20ft of glowing red wire that seems to be wraped around everything. Not good.
