Motor issues
Results 1 to 13 of 13
Motor issues
    Mar 2014
    Default Motor issues
    Having issues with my boat not wanting to go over 3000 rpm when it's under a load. In the drive way it runs fine. Changed all the spark plugs out it will take off in the water to 3000 rpm then just bogs out. Any suggestions? Need to get this thing going just bought the boat 4 months ago and the guy said he just got the jet rebuilt by jet boat performance and the old owner put a new carb on himself
    Tacoma Wa
    Have you checked the pump to make sure it doesn't have anything in it?
    Surprise, AZ
    It ain't in the pump. Timing or carb issue. Check fuel pressure, float level, timing.
    Sent from my VS980 4G using Tapatalk
    Senior Member Futs's Avatar
    Orange CA, Big River
    does it have an MSD box with the wrong pill in it?
    Surprise, AZ
    X2
    Been there,done that.
    Quote Originally Posted by Central coast mud sucker View Post
    At the time we rebuilt the jet the previous owner was advised that the Edelbrock carb that was on it needed to go and that the engine/boat needed work the fact that it runs ok except under a load suggest fuel and electrical issues ...
    Senior Member 787chuck's Avatar
    MorePark
    Disconnect the pump and see how it spins to rule it out then check your tune up full throttle float level trimming and so on is the new carb a Holley with vac secondarys if so are they working
    Colorado Springs, Co.
    Make sure you're getting 34-35* total advance. It sounds like the dizzy may not be advancing. Stuck/sticky advance plate maybe?
    1978 Glastron/Carlson CV23; 429, Berk jet.
    Senior Member bc18's Avatar
    Quote Originally Posted by 86NovaII View Post
    Or just lock it out
    What brand and what type of distributor do you have?
    Jan 2013
    Magic Mountain CA
    Clogged fuel filter or water seperater will cause your symptoms. All good posts, I would start with fuel system from the tanks through carb, then to ignition. I'm betting fuel issue.
    Mar 2014
    Thanks guys going to start with the fuel system first and pull the edelbrock off and go to a holly, change out the fuel filter also will keep you guys posted thanks for all the help brothers
    "I'm just SPRAYIN' man!!" '78 Crusader's Avatar
    Oct 2010
    McKinney, Texas
    Timing was mentioned earlier. I'd put a light on it and see what the initial timing is at idle and then what the total timing is at 3000 RPMs....just to see if the timing is advancing properly. I had a similar issue with my motor a while back, come to find out I had a stuck counterweight in my dizzy. After you check to see if your timing is correct, I'd then check out everything else that was mentioned.
    Cliff
    1978 21' Crusader, 466 CID BBF, Berkely Jet
    1966 13' Boston Whaler sport, 40 HP Yamaha Two Smoker
