Jacuzzi impeller?
Results 1 to 14 of 19
Jacuzzi impeller?
    Senior Member crf311's Avatar
    Meraux, LA
    Default Jacuzzi impeller?
    Does this look like a SS impeller ? When I hit it with a screwdriver it does have a little ring to it. Thanks
    Senior Member bp298's Avatar
    LHC
    looks like a ss red x to me... could be an aluminum red x though..
    Meraux, LA
    yea looks like a red x to me also but is it a SS red x. How in the Phuck do you post pics. I put the dam thing in my folder, copied and pasted the url and it still don't show, O well
    after you click on the mountain icon delete the htp// (make it blank)before you paste.
    Senior Member wajetboy's Avatar
    Auburn, WA
    is this the pic you wanted? i used the thumbnail version the other one was huge, it looks alum. to me.
    Meraux, LA
    thanks, wajetboy
    Denton, TX
    Remember mine from my jacuzzi rebuild?
    Turns out it was Aluminum.
    Meraux, LA
    Quote Originally Posted by Btnhtillidie View Post
    Yes I do . A re read it a few times. I think i'm going to sand on it a littleto see if that might shed so light to it.
    Your Impeller is a rare Jacuzzi WJ "PW", the Pw was a late 70's Jacuzzi performance offering , To use it in a WJ required cooresponding bowl machining. The PW is fairly aggressive and tends to "act" a cut above its standard WJ siblings. We have PW "AA" in "Project Miller" ( a budget boneyard destined resurection) that runs just shy of 80 mph with a 434 cu stroker BBC I'll dig up some pics , more info if you interested Tom
    BTW I'm sure its Aluminum
    "edit" ,found some pics ... wj vs pw comparisons
    Bowl
    Meraux, LA
    Tom, Thanks, I going to give you a call friday if I get a break at work.
    Quote Originally Posted by crf311 View Post
    Check pms for my cell Tom
    Denton, TX
    ahh I wish mine was "Special" the only thing Special about it is how hard it was to get some of the shit apart!
    Theres always this upgrade you guys if your interested
    Meraux, LA
    Yea that looks sweet, but I'm low on funds right now. My problem is I have a jacuzzi on my boat right now that I know is in bad shape. I have the one above which is in good shape, which i might use for now. But I also have a berkley jc a which I could also put in. All have diverters also. Just looking for a easy, fast, and least expensive way.
