I need advise On a daytona
Results 1 to 10 of 10
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    Default I need advise On a daytona
    1st I found a a 19 ft Daytona setup for a wacker is the conversion to a jet real technical I have all the time in the world to do it but never even set an intake
    2nd fire damage on fiberglass is this a huge thing to fix I have a limited knowledge of fiberglass but alot of time to do it
    This is more than likely the only way I will get in one of these hulls atleast for a long time alot of knowledge here if you guy can help I would appreciate it
    Lexington, KY
    Talk to Tom at JBP, I'm pretty sure they did a whacker to jet conversion not that long ago.
    Good luck.
    HJ
    [IMG][/IMG]Tom did mine, I think it depends somewhat on the center sponson, is it a flat or round keel. I've heard/been told a flat keel you'll be somewhat limited on what kind of hp you can throw at it (loading wise).
    Senior Member junkyard's Avatar
    PHX AZ
    Now that the jet is in, is your flat keel or dose it still have a little bit of round keel to it. Iv got a 18ft cat that was built for a outboard and I bought it to put a jet in it and it looks just like yours did. My outer sponsons have a little bit of flat to them as well before angleing upwerd.I allso wasnt sure if the center sponsen needed to be droped a litle.
    If you look at the pic on the right close you can see mine's rounded. I think I've heard Greg in the past say that some daytona's(19's) ...... that were born outboards either had no center sponson or that the center one was raised somewhat. Don't qoute me on that, I could be wrong, I don't want to mis quote the guru.
    Senior Member War Canoe's Avatar
    Like Sabwafare, I am everywhere
    Default I stayed whacker...
    made more sense...
    19' Cougar 300XS 110MPH + 5 years of sponsorship, uhh I mean warranty !
Name:	November 2008 Delta rip098.jpg
ID:	24919   Click image for larger version.
Name:	November 2008 Delta rip002.jpg
ID:	24920   Click image for larger version.
Name:	November 2008 Delta rip024.jpg
ID:	24921   Click image for larger version.
Name:	November 2008 Delta rip081.jpg
ID:	24922   Click image for larger version.
Name:	October Delta run 08003.jpg
    Senior Member HavasuDreamin''s Avatar
    Indianapolis
    I have a 19' Daytona that was born (and still) and O/B. It has a flat keel that is even with the outer sponsons. I have seen a 19' Daytona O/B that had no center sponson. It was a rare bird (one of only a few) and loved to fly.
    19' Eliminator Daytona
    21' Ultra LX
    two strokes is enough
    Yuma, Az
    the ones with no center sponson were only made between 82 and 84 i believe and they are usually a super light layup robdog has one but that boat was once a jet idk how but ti was once a jet so anything possible apparently
    Yuma, Az
    Quote Originally Posted by HavasuDreamin' View Post
    yah they are definately rare and hard to come by but your definately right about loving to fly ive ridden in a 21 and that one is a little odd feeling but cool at the same time
    Fort Worth Texas
    I dont know I think this one has to many issues I am going to pass on this one Thanks for the help guys Eric
