watts regulator help
Results 1 to 3 of 3
    May 2014
    Default watts regulator help
    need to put a water pressure regulator on my jet but cant get a straight answer on what to use id like to just used a watts regulator but dont know what part number to use any help on this would be great thanks
    Tacoma Wa
    jet boat pressure bypass kit That'll do it for ya you want the valve to bleed off presure around 15 psi or so.
    Jan 2012
    St. Louis, MO
    I used a Watts N45B-M1 regulator. However, I removed the spring and substituted a McMaster-Carr part number 9435K151 spring in order to get it to regulate at a lower pressure. I set mine at 7 psig on my BBC, and it never runs over 140 degrees (F). If you do this, set it up on a garden hose with a pressure gauge to verify it's working properly.
