455 crankshaft
Results 1 to 14 of 14
455 crankshaft
    Default 455 crankshaft
    How deep scratches/grooves are allowed on the rod and main journals on the crankshaft ? also not sure if it needs it, but if the crank needs to be turned down does it effect the life of the crankshaft without heat treating it afterwards?
    On the OLD's crankshafts, it's standard procedure to cut them, to reduce the bearing's surface speed on the mains.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Scratches = Friction. It is my understanding that the Olds has an oiling problem as it is.
    Wags
    Newton Ks.
    Well, the Olds oils really good, so no problem there.
    It's more of a drain-back problem from the heads.
    It oils just fine till the pan runs out of oil to pump north, then, it gets expensive.
    H.L. Mencken
    Quote Originally Posted by dgie View Post
    Maybe post up a pic ? Old school rule ,if you can catch the scratch with a finger nail its way to much to ignore , might polish , needs to be assesd and mic'd by a pro to know .The more you turn it 10,20,30 the thicker the brg shell neccesary , poor heat transfer etc . Even though OE Olds cranks are getting scarce if yours wont "polish" standard look for a good STD core . Olds lower ends are way to touchy and too expensive to fix to risk a marginal piece. Check out some of the after "replacement" Cranks available to you too I think Eagle may have one now ? Tom
    heres an example ..http://spideraccessories.stores.yaho...104554260.html
    Monroe, WA
    Not really...
    An old trick I heard of was to rub a penny across the journal and if it leaves any copper behind it's bad. Kinda goes with the fingernail test.
    I've polished mine before with good results. You want them a thou or so loose anyway.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    You have the "cart before the horse" there Smokin. The Olds does have an oiling problem--insufficient oil to the rod bearings. This problem is magnified by the drainback issue. The primary purpose of the restrictors commonly used in the Olds is to bias more of the oil flow to the rod journals, the secondary effect is reduction of what goes up to cam and valve train. Had the GM engineers set the oiling system up with more flow to the rods, we would likely never heard of any "drainback" issues.
    If you are talking about cutting them down from the stock diameter of 2.5" down to, lets say, a big block Chevy's 2.2" diameter, then that would yield a substantial reduction in bearing speed. Simply cutting them to a normal undersize of -.010", -020" , -030", will have a very minimal effect on bearing speed.
    Nice to see someone is finally making a replacement Olds crank. Now they need to do a forged one and a stroker. Almost makes me wish I still had a 455 to play with.
    how about heat treating afterwards, is it necessary?
    Smokin I just seen your post on the other thread on this.
    El Cajon, CA.
    I don't know where you are, what your finances are like, or what cut your crankshaft is currently at... but if it turns out you need a different one, the Eagles are around $500, I have a stock Olds cast crankshaft that could use a re-polish, it's already cut at 30/40, bearings are available for it from Summit, and you can have it if you need it plus shipping. Either way, good luck.
    I'm baaaaack... hkunz's Avatar
    Lake Havasu
    I'm on my second turndown, now at 0.020" under. Not sure if I'd chance racing it, but it should be ok for sport boating. If I was gonna race I'd probably get an LS2 and start from there
    It is impossible to defeat an ignorant man in argument. -William G. McAdoo, lawyer and politician (1863-1941)
    07 Advantage X-Flight 600 SCi Bravo 1 XR
    04 Cheetah Scorpion 6.2 Bravo 1 - SOLD!
    96 Donzi 21' 454 Bravo 3 Medallion - gone!
    72 Tahiti 16' 468 Olds Berkeley jet - SOLD!
    11 RZR XP, 08 Polaris Scrambler, 06 Rhino, 06 Joyner 650 dune buggy, 04 KFX 700
    Newton Ks.
    Ah, I was unaware of the rod-oiling issues, this is the first I have heard of it. Thx and duly noted.
    I suspect you maybe right on the bold line.
    H.L. Mencken
    Newton Ks.
    Besides, if you DO re-nitride it, I am 99% certain it will need straightened afterward. I am sure it will warp a bit in the process. Not a problem, just what happens.
    H.L. Mencken
