Ball valve
Results 1 to 12 of 12
Ball valve
    Mar 2014
    Default Ball valve
    Hey guys I have another rookie question for you
    do I have to run a ball valve and what exactly does it do
    thanks nic
    Senior Member Scapegoat's Avatar
    SoCal
    More info on what you talking about....
    Mar 2014
    Quote Originally Posted by nkaragon21 View Post
    thanks nic
    This is for the cooling lines of course
    Mar 2014
    Quote Originally Posted by Scapegoat View Post
    I think it's the check valve ? That is on the water line from the jet
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Some guys run a ball valve to limit the amount of water getting to the engine. To allow more or less engine temp.
    Some think the valve at the pump outlet will allow air pockets in the engine. Some put them after the engine but then the engine will see full pump pressure.
    The best setup is a relief valve instead of a valve in line.
    QE 439 Twin Turbo
    Mar 2014
    i the check valve do I have to have it
    Mar 2014
    Perfect thanks. One more question. I put a T fitting in the line from the jet an plugged it. But when I go to hose run it is that where I would hook the hose too ? Or is there a different setup ?
    Assuming your refering to a "T" so that you can run the boat on a garden hose ? (assuming you elect to do this) the place to for the "T" could be eiher before the ball valve at the jet casting outlet
    Mar 2014
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Default Check Valve
    Ball valves restrict water flow and create air pockets in your engine. I would use a check valve set at 8 to 12 PSI with the excess water being dumped over board.
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by PCE680 View Post
    Ummm - you meant to say relief valve, right?
    To the OP: IMHO, the ball valve is only there to allow you to shut the water off if you're on the lake/river and you blow a hose or a freeze plug.
    And to stir the pot on this (again), I'm going to say he should use a pressure regulator instead..... ;>)
    Quote Originally Posted by mpkardell View Post
    Ya can call it what ever you want but is does adjust the water pressure to the motor.
