Wear Ring Removal
Results 1 to 14 of 20
Wear Ring Removal
    Senior Member xxtremez's Avatar
    Jul 2013
    Texas
    Default Wear Ring Removal
    I am sure this is out there somewhere, what is the trick to removing a wear ring? I have a shouldered wear ring with a non shouldered insulator. I heated the wear ring with a torch until it glowed red and the insulator never melted. I tried a pry bar and screw drivers. It will not budge. Any help is appreciated.
    Thanks in advance.
    Fo Show
    If its trashed cut it out or try heating up only a small area then throw cold water on it, sometimes theyll crack like a bearing race will
    Quote Originally Posted by xxtremez View Post
    Thanks in advance.
    Pics ? somethings odd here , usually the degerading insulator will smoke and actually catch fire and the fumes will empty the shop , what color is/was the insulator ? Tom
    Jul 2013
    Texas
    I cant tell what color the inslulator is being it does not have a shoulder. Ill get a pic and post it. Its a brass wear ring.
    Fo Show
    Jul 2013
    Texas
    I thought about trying to crack it by heating the wear ring then spraying it with nitrous. I was concerned about damaging the housing though.
    Fo Show
    sounds dangerous ... Pics would still help
    If its the same dominator housing i put in the boat i pinned the wearring to the housing.had the small o.d. wearring housing that had to have ring made by tom jbp.may not be same pump tho
    Jul 2013
    Texas
    Its a berk, I am taking it apart due to clearances being way off. I am trying to figure out why. The impeller to wear ring clearance is like .130 with no shims. I think the person that had the boat after you put a different pump in it. I am just going to start over with wear ring and impeller. I think its odd that the shoulder is all the way against the housing on the wear ring. I dont know much about these, I am learning though. Ill take a pic tomorrow and post it.
    Fo Show
    Thumbs up
    Oh good, id rather have that berk than a small wearring dominator. better option for wearrings! Are u gna run a ultimate wearring? I bought the last small o.d. ervin capps had and put it in that dominator housing and flowed the shoulder to the suction housing and pinned it so itd stay there.had a dps inducer and aa cut ss amt in it when i sold it.
    i enjoy seeing that boat at meets, had alot of fun in it and you ve got it look really good!
    Favorite pix of when i had it. Kevin had a shairoff built 555 with big nitrous and we d go at it summer after summer lol.got to where i didnt lose anymore against him tho with my lil homebuilt 505 on the bottle
ID:	598474   Click image for larger version.
    Jul 2013
    Texas
    Thanks, I have put a lot of work into it. Its still a small CI motor, I just built a nitrous system for it. Its stand alone and I am running it off of the left tank. I want to get everything right before I start spraying it. After I get the pump square I can see how much this motor will take then possibly build a big NO2 motor for it. I am only as fast as my wallet
ID:	598530   Click image for larger version.
    Fo Show
    Jul 2013
    Texas
    Here are the pics of the wear ring
ID:	598546   Click image for larger version.
ID:	598554   Click image for larger version.
ID:	598562   Click image for larger version.
ID:	598570   Click image for larger version.
    Fo Show
    Dec 2010
    Sapulpa ok
    Drill straight into it
    Quote Originally Posted by piston in the wind View Post
    Yep thatll weaken it!
    Hot torch line frm frt to back and ice cold water is worth a try tho. do it alot at work to fracture bushings and races.u can also braze a few beads6-7inches long around it and itll shrink the rings.. with steel races regular ole 6011 rod works but id bet brazing rod will bead fine on bronze and when it cools shrink up the ring some
