### jet
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 100
### jet
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default ### jet
    Does anyone have a jet boat with a normally aspirated engine, no nitrous on pump gas that does 100+ mph?
    So Cal
    yes, lots do & have ... I'm sure they'll post up shortly
    cyclone used too he's the only 1 i know of. there's a blown pump gas 496 tx20 here local doin 103 on pump gas, but its getting stretched out to do it.
    So Cal
    I thought Hass was able to run pump gas???
    Cyclone, CS19, Fuelinmyveins, Blytheonian, etc. all had pump gas motors that ran over 100 before switching to n20 motors ... they still can I think, but they get crazy with the button too much I think.
    They can post up more accurate information, but I know that they all were based on pump gas builds at the beginning. Maybe not CS' new motor ... but his old one for sure.
    Lake Havasu
    Quote Originally Posted by BUSBY View Post
    Are these engines normally asperated, No blower or turbo and without nitrous and on pump gas?
    true, but's its not na there's noooone around here doin it na, just not enough $$$$ around here to do it.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by Master Sergeant View Post
    until last winter, i routinely ran over 100 without blower/turbo/nitrous on pump gas for 6 years... not a ton over, but over, in a antique heavy hull... why do you ask?
    No one said it was easy or cheap :
    http://www.royalpurple.com/sport-truck-2.html
    Sleeper CP
    Senior Member Futs's Avatar
    Orange CA, Big River
    mine is a pump gas motor. I have even ran 87oct. in it for about 2 miles once just to get me back to the ramp. 10.2/1 comp. It won't run much over a hundred.
    So Cal
    oops my bad, forgot, he said n/a
    So Cal
    yes ... without turbos or blowers, wasn't sure about bp's ride with or without nitrous & , also there's others within the NJBA ranks ... I think Widowmaker has tuned for pump gas but mixes with 110 to make a 100 octane to run more timing.
    Default pump gas at a 100
    With a good hull,good pump ect. a scott shafiroff 540 pump gas motor will do the trick. good luck......
    Quote Originally Posted by boatfreek View Post
    i've seen a race weight tx18 with a scott sha.. 555bbc 13.5 to 1 not get there, i wasn't impressed that's a bubba backwoods built 13.5 to 1 505bbc powered lake weight hull in frt of it
    My Cp with a 468ci Paul Phaff engine that made around 630hp would run 10.70 ET at 97 mph.That was 6-7 yrs ago.Its not hard to make 750hp now days.With the right combo a good jet boat should or can run 100mph.A good jet and bottom hardware is a must though.
