end of the summer motor problems
Results 1 to 14 of 27
    Broke Member monstertahiti78's Avatar
    Feb 2012
    Folsom, CA
    Default end of the summer motor problems
    I dont even know where to start.....I had to replace the gas tank in my 74 Tahiti (455) due to rust on the bottom of the original tank. Once replaced I took her out for a test run and she started bogging down at low rpm. Almost seemed like some carb adjustment or timing. (Which was interesting because it ran great before I put the tank in and I did not touch the motor at all). If I kept the rpm about about 2000 it ran perfectly fine. Any less than that it would make a very low popping noise and run like shit. So I parked the boat and it sat for a couple of weeks until I had some time to work on it. Finally got around to working on it and fired it up to show my pops what it was doing....and of course it ran just fine. no issues at all. since I was already in the tuning mode I pulled the plugs (cleaned and re-gapped), checked and cleaned up rotor, checked dwell, and adjusted idle. From that little bit of tuning she was running better than ever or so I thought. I took her out to the river a couple of days later and spent about hour cruising around with no issues at all. Then out of nowhere I started hearing the low popping noise again but this time is was not at low speeds this time. Now it was happening when I got it up to around 2200-2300 and ran totally fine at low idle rpms. And when I got it up to around 2300 the motor was shaking back and forth pretty hard. Puckered my a$$hole a little bit. My first thought is a fuel issue. Maybe clogged filter or something in the line. I havent had a chance to dig into it just yet but I thought I would put some feelers out there and see what you guys thought. Motor is all stock 455. Thanks for the help in advance.
    Rancho Cordova. CA
    I would bet some of that rust is in the filter (s). Possibly in the carb as well.
    Feb 2012
    Folsom, CA
    Quote Originally Posted by carreradude View Post
    Im thinking the same thing. Of course all of this happens after I sold my whole fuel system off of the last boat. Where in Rancho are you located? I live in Rancho as well.
    Tacoma Wa
    Id flush the lines and pull the float bowls to see if you have rust in the carbs plugging it up.
    Jan 2012
    St. Louis, MO
    The fuel pressure gage is your friend....
    Shell Knob, MO
    All of the above posts were good things to look at. If that's not the answer, does it have an HEI distributor in it? Check the wires running to the module if it does.
    Feb 2012
    Folsom, CA
    Quote Originally Posted by LuckyDaze View Post
    The old boat had a Edelbrock on her and I went threw both the carbs a handful of times. With that being said I have no problem going through a Edelbrock but I have no idea what im doing with the Holly on the new boat. I would assume it cant be much different. Ill probably dig into it on Saturday and see what I come up with.
    Feb 2012
    Folsom, CA
    Quote Originally Posted by mpkardell View Post
    No fuel pressure gauge on this setup but it may need to be added for personal comfort this time around.
    Feb 2012
    Folsom, CA
    No HEI on this setup. Stock points.
    Nov 2009
    Quote Originally Posted by monstertahiti78 View Post
    Ballast resistor!
    seattle
    Default Vent
    Just a thought...you change gas tanks...is the new one Vented Properly??
    75 Eliminator
    New Jersey
    Do yourself a favor and upgrade to electronic ignition. Points were okay when we had nothing better. I think you can do a Pertronix conversion for not a whole lot more than a new set of points and condenser and the Pertronix works well. Or if your budget allows there are all sorts of distributors from MSD and Mallory, DUI etc. Even if it is not the problem this time you have just enhanced the performance and reliability.
    Doug
    Feb 2012
    Folsom, CA
    Quote Originally Posted by 1975sleekcraft View Post
    I think it is....vent tube to the side of the boat. I reinstalled the new tank the same way the old one came out. Is there something aside from the vent tube that I should have done?
    Feb 2012
    Folsom, CA
    Quote Originally Posted by Real McCoy View Post
    Doug
    I agree. I had a MSD on the last boat and I loved it. The only thing is that I cant see putting anything more performance wise into this 455. I havent touched the boat mechanically since I bought her(up until the recent tune up) and she ran great up until this point. Super reliable all summer. I really like the reliability of this boat but the reality of it is that its just a starter boat for me. I think if I start throwing money at a motor I want to do it to a 454.
