olds 455 crank slinger rubbing
    Apr 2011
    Default olds 455 crank slinger rubbing
    olds 455 crank slinger seems to be rubbing and wearing on timing cover. I pulled the oil pan and timing cover to fix oil leak and slinger seems to have worn a groove on bottom 120deg of timing cover. Cover was brand new on rebuild. I loosely reassembles without Hardin front mount and slinger does not rub. when hardin mount is re-installed it slightly pushes in on timing cover ad slinger rubs. Original gasket was 0.030, now I have a 0.020 so I believe the slinger will wear another 0.010 into cover. Anyone have this problem with the Hardin engine mounts? It does not appeat bent. Should I grind the rear to relieve pressure off the timing cover?
    Quote Originally Posted by thecoralreefer View Post
    Toss it it will never make a difference (Olds Tech Class of 75')
    Apr 2011
    problem solved, i used some thin washers to space hardin mount about 0.030" from timing cover. no longer pushes cover back into slinger. now my only concers is what those metal shavings did to my $5000 rebuild
    seattle
    hopefully the filter caught them !!!
    75 Eliminator
