[Announcment] 460 ford harman logs and snails needed
Results 1 to 5 of 5
    Aug 2014
    Cool 460 ford harman logs and snails needed
    Hi new here looking for logs and snails for 460 for along with water pump plate.
    Peter
    building a 532 ford stroker and need good exhaust for it
    it's going in a glastron cvx 20 or 23 ,, I have both but i need a good exhaust that's water cooled since it's enclosed
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Quote Originally Posted by craneman View Post
    Peter
    Call Jim Brock at Cyclone Marine 818 890-1867 He has them.
    Colorado Springs, Co.
    If you're planning on making more than ~475-500hp, logs won't work well. If you do source logs, the long-bolt logs flow better than short-bolt logs. Upswept 4-bolt header style manifolds flow well, but can't be used with tall valve covers.
    With a large increase in torque over the stock 460, the 3-point engine mounts will be insufficient. You'll need either a 4-point mount set or a rail kit. A rail kit will work even though the Carlson's have narrow stringers; ~22". You can use a standard rail kit and notch or section the rail for starter access, or source a 460 rail kit setup for a top mount starter.
    A stock 5qt oil pan is marginal for a higher HP build, and a larger oil pan requires a 4-pt or rail kit mount.
    I've seen a CV23 with true, water jacketed headers. Part of the storage area above the engine was opened up and insulated for header clearance. Was a very nice looking setup.
    1978 Glastron/Carlson CV23; 429, Berk jet.
    Peter
    Have noticed on several Glastron 460 jet applications that the manifolds are angle milled at the exit so that the snails angle in slightly (due to hull and transom configuration) The majority of the 460s for these boats seem to also use what we call the "long bolt" style of manifolds which seal better
    Aug 2014
    Default 460
    I have a set, along with MSd billet dist,
    Has Dooley pan
    New MSD
    New Carb
    Take the whole engine for $1200.00 with exhaust ,two rods bent
