Little wireing help please
Results 1 to 14 of 36
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    Default Little wireing help please
    I will be rewireing my boat this winter but I need to see how to run across from the engine to the deck and make it look clean and a safe run can you guys post some pics of how yours are run across Thanks Eric
    Kingman/Golden Vly, Az
    Quote Originally Posted by TahitiRat View Post
    if ur referring to running the wires from the motor to the instruments etc in the dash, there was a thread on here that showed how peeps did theres with pics
    FastRat
    Fort Worth Texas
    I have been looking for that but cant seam to find it dose anyone rember the name of the thread
    El Cajon, CA.
    I think it was Hawiian jets thread, maybe he'll see this one and post up a link...
    Cantard 71hallett's Avatar
    snow bank
    Fort Worth Texas
    Is it ok to run the wire harness down the side of the block to the outboard side of the stringer under the floor and up the transum will the wire get wet and cause a problem
    Lexington, KY
    Nope not mine, and please don't look at mine. There are better ways to route the wires than what I did. Squirtcha? did a really clean wiring job on his boat, might check out his thread, I think Busby started the thread.
    But there are a few wiring threads on here somewhere, with some great pictures and some really good info.
    Good luck.
    Here's Squirtcha?'s thread.
    Sounds like a smoking deal
    HJ
    Colfax, Ca
    I have used this in both of my boats.
    http://www.etrailer.com/pc-trw~127C500-1.htm
    Fort Worth Texas
    Thanks for the help I just dont want to wire this wrong and have a big problem
    Fwiw having a custom harness made it way too easy , mind you mines not close to being 1/2 as clean as Squirtcha's, I just called Tom (jbp) gave him some measures. Everything is color coded correct and fit like a glove. I'd like to know where to get a nice mounting bracket for a terminal block, I think I'm ready to retire the piece of cut off sheetrocking T square I used.lol
    El Cajon, CA.
    Wire being wet by water in itself won't cause the wire any harm, but fuels and oils will harm a wires insulation even if it's oil reisistant. With that being said, I'd run the wire up the side of the gunnel before I ran it under the floor. IMO
    Don't hate the sheetrocking T square, LMAO.
    Fort Worth Texas
    I think I am going to fab one up out of alum. and polish it
    I fiberglassed pvc pipe up the right side deck[make sure u miss gas filler neck] and a short pvc pipe on the transom to hold all wires. Way better than having them loop along the gunnel where you can see them. Pat
    Fort Worth Texas
    I didnt think of that I think I will try it Thanks
