Bowl Clearance
Results 1 to 7 of 7
Bowl Clearance
    Senior Member gregb's Avatar
    Redondo
    Default Bowl Clearance
    Recently I took my impeller out to get it cut down a size, before removing it I checked the clearance between the bowl and the back of the impeller and it's close to an 1/8 inch. (used the play-doh method). Was thinking of putting in a stuffer. What is an acceptable clearance range for that area? What are you folks running for max efficiency and performance out of your jets? Thanks,
    Greg
    Greg
    i think everyone i've ever asked that question had a different answer. 1/8th is fine, close'n it some helps, opening it up hurts alot. i've had to cut a few bowls at the flange to draw in the bowl some to the impellor, holeshot got meaner for the effort.i'd have to see my notebook on the tx19, but i think i had alil less than 1/8th at the back(dominator bowl with dom style stuffer ring), and a 1/8th min at the veins(with a amt ss aa cut).
    The Impeller is always wanting to push the pump shaft forward thru the bow of the boat,virtually no aft movement , you could safley close it up quite a bit from .125 Tom
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Uh oh............ so mine's a "little" tight then Tom
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Kyle ,as close as .015 (maybe) to .030 if your confortable with it Tom
    You can build a simple stuffer plate out of .100 aluminum, center diameter enough to clearance shaft and nut, outer diameter is the same as the center of the bowl (about the diameter of the back side of the impeller) Secure it with 4 to 6 stainless screws, drilled, and tapped into the bowl. (counter sunk screws)
    Shell Knob, MO
    That will work fine, but we feel it is best to use the coned type stuffer to eliminate the volume of water that the impeller has to churn back there.
