Safely removing my boat from the trailer
Results 1 to 14 of 25
    Aug 2014
    Default Safely removing my boat from the trailer
    I need to replace the carpet on my trailer and I'd like to paint it. Would it harm the boat to lift the rear by the engine with an A-frame or cherry picker so I could pull the trailer out and get the boat on proper stands while I fix up my trailer? If not have any suggestions?
    Senior Member bc18's Avatar
    Quote Originally Posted by jarguess View Post
    Not at all
    Multiple ways to skin a cat , you might just secure the boat to something solid and slowly pull the trailer out from under it with truck or winch while shoring up the boat as you go or go creative with shop cranes and ?? ..
    Tacoma Wa
    I recognise that boat!
    Mohave Valley/Quartzsite
    Here's how I did mine..
ID:	616353Click image for larger version.
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Aug 2014
    Awesome guys!! Thank you!!
    Tacoma Wa
    There are few things more unerving in this world than seeing a boat suspended off the ground five or so feet! Good luck with your project boss!
    Aug 2014
    Lol hell it was unnerving to see all of yours
    Tacoma Wa
    Mine still floats for now so it survived! Take pics of yours when you pop her off the trailer!
    Aug 2014
    Will do
    Mar 2010
    Clarksville, TN
    Not a bit. Picked mine up by the pump and had sum buddies pick up the front.
    Senior Member nikwho's Avatar
    Here is how I did mine. I am lucky, but doing it at home with a couple of cherry pickers as a previous poster showed. I was more comfortable with the strap under the hull, but if your stringers are in good shape and your hardware is as well, I'd be comfortable with lifting by the engine. Just probably not one of those I take manifold plates! That might put a bit too much weight on your carb studs.
    Whoops. Forgot to attach the picture.
    Senior Member River Dad's Avatar
    Riverside, CA
    Umm, what is holding up the front of the slayer in that pic Mike????
    Looks like David Blaine street majic or something......
