Street value of JG pump, hydraulic diverter + droop snoot?
    Senior Member nikwho's Avatar
    Default Street value of JG pump, hydraulic diverter + droop snoot?
    Hello, I am curious what kind of Price to expect to pay for a used 12 JG pump, hydraulic diverter and droop snoot. There is one available locally that has not been in the water for a few years. I have not gone and looked at it in person yet, but it very well may need to be rebuilt. I was considering buying this pump and not putting any energy or money into my 12 JC pump. I realize that I'm probably asking a pretty arbitrary question, and there are many factors involved, but I'm just trying to get a rough estimate of a used pumps value.
    thanks in advance for your help,
    Nik
    Anaheim Hills
    Diamond Bar, Big River
    you are only a bowl change away from having a JG pump. If your pump is in good working cond. the bowl swap is the cheapest, easiest way to go. Have you run this boat prior to the restoration?
    Quote Originally Posted by NiceGuyEddie View Post
    I tried! Sold already. But, thank you! That helps me understand the value of that type of setup!
    Quote Originally Posted by jetjunky View Post
    I have not run the boat. I suppose that I should probably just build it with the parts I have and see how it does? Then just a bowl swap would be in order if I needed the droop or diverter.
