What did I buy, Hull ID
Results 1 to 14 of 64
    Sep 2014
    Rockford Il
    Default What did I buy, Hull ID
    I just bought this 89 eliminator Jet. Never owned one before. it has a 454 Hardin motor and a Berkeley jet mounted outside of the boat. I wondering what the name of this model is and what the performance potential is?
ID:	617001   Click image for larger version.
ID:	617009   Click image for larger version.
    Apr 2009
    San Diego, CA
    Looks like a river cruiser to me...
    As I recall mine was called an Eliminator Sport cruiser , Very Nice boat congratulations !
    Sep 2014
    Rockford Il
    Good perf hull?
    Senior Member RogerThat99's Avatar
    Aug 2010
    That sounds right to me also.
    "I Love Haters" - Its not a frame of mind for us...IT'S A LIFE STYLE!!!
    http://www.performanceboats.com/signaturepics/sigpic17778_1.gif
    Just Me snoc653's Avatar
    Eastern Iowa
    Quote Originally Posted by horsepowerjunkie View Post
    Good perf hull?
    The definition of performance varies greatly. This is a performance boat site and you will find everything from 200+ MPH fuel boats to 12ft mini boats running jet ski engines. What is your definition of performance?
    If its a 50 to 70 MPH family fun boat that can handle the lakes with some chop, pull the tubers/skiers/wakeboard; then yes it will perform quite nicely. If its to run 7 second quarter miles or 100 MPH plus sprints; I'm afraid you will be disappointed. Anything is possible though. All it takes is lots of money, horsepower, work, and more money!
    Diamond Bar, Big River
    Default nice toy
    Wow, very nice purchase there for your first jet boat. What kind of performance did you have in mind for it? In earlier years they called it a "super sport" cruiser. Not sure if they changed the name in later year models or not but they did move the dash forward giving more cockpit room. My '78' model the cockpit is only 9' long inside, it gets real snug with a rear bench seat style interior arrangement. Your boat will perform very well in most all applications. Busby here on the boards has a very nice one that is said to run well into the mid 80 mph. range with about 700 hp. It appears yours has a set back pump in it (the hand hole cover is outside the transom). If it was done correctly you should be able to put a substantial amount of power to it and obtain very good results. How does the boat perform currently? Does it porpoise (bow bounces) any or does it take a nice stable set and cruise/run out nice and smooth/steady? It sure appears to have been well maintained, looks like you scored.
ID:	617033   Click image for larger version.
ID:	617041   Click image for larger version.
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Eliminator called that hull a 20 1/2 Eliminator Mohave.
    Sep 2014
    Rockford Il
    Quote Originally Posted by jetjunky View Post
    Thanks. I thought it was so nice I didnt want to pass it up. Not really looking for a boat at the time. It is tight inside. It does have the set back pump too. Iam glad the hull is at least one that responds to power well. Mid 80s would be awesome. the guy I bought it from said he GPS'd it at 71. Ive had lots of prop boats, very fast ones at that, and that seems high to me. it ran low 60's with both of us in it but I didnt wring it out. I was a little dissapointed with the midrange punch. the whole experience felt kinda mushy like, unlike the prop boats. Im not sure what kind of 454 is in there. rectangle or oval port, cast pistons and or crank. Was thinking about: A. more inches or B. like a 250 shot. Do lots of fellas run nitrous?
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    I'm going with 20' Sport Cruiser. I had a 1978 model.
    Mohave was a 21 and had a taller deck
    Hallett called there 20' a Super Sport.
Name:	78 Dodge Van 002.jpg
    Sep 2014
    Rockford Il
    More photos
ID:	617065   Click image for larger version.
ID:	617073   Click image for larger version.
    Sep 2014
    Rockford Il
    Quote Originally Posted by 76 Bonneville View Post
    I love that van!
    San Diego, CA
    Remove the rudder and have MPD detail the impeller. Would probably be a good start
    Boat 405.
    Sep 2014
    Rockford Il
    im sure the rudder is easy. what needs to be done to get the impeller out? What would one expect to gain with the detail job? I love this stuff.
    how much power does it take to gain 10 mph? About like? I know in an I/O I needed 100 hp to get ten
