Wedge question
Wedge question
    Senior Member obie's Avatar
    Feb 2009
    Default Wedge question
    So I ran across a pile of aluminum wedges that I done need, my question is how are the degrees measured? I have tried checking them very and horiz but it doesn't match. I have several that are marked 8* that check out at 4*. Just want to be honost on what I have , any thoughts? Thanks
    At the end of the day do u really wanna be seen driving a wacker?
    Zero out your digital angle finder on a flat surface lay wedge on surface and angle finder onto wedge.pretty easy.
    Feb 2009
    Default Ditto
    That's exactly what I did but thanks.
    I believe there was a set of two 4* that were made to be used together to give a larger selection of tuning/degree.
    Made In The Shade
    Custom Window Tinting
