460 dipstick for Armando's Pan?
    Colorado Springs, Co.
    Default 460 dipstick for Armando's Pan?
    What dipstick is recommended for a 460 with an Armando's 10qt pan? With ~10qts in mine, my dipstick only shows oil on the tip of the stick. It'll only drop in one way also. Stock timing cover with dipstick at top.
    1978 Glastron/Carlson CV23; 429, Berk jet.
    Shell Knob, MO
    PM sent
    To keep the oil from running/dripping out while in use... leave the dipstick off when in use and put a vacuum line rubber plug over it. Joe at JP told me about that a while back and been using it that way on my BBF for years.
    Made In The Shade
    Custom Window Tinting
    Aug 2009
    I've got an armondos pan also for my 532 (460) i got a universal dip stick and shortened it so it would set on the tube tightly without touching the bottom of the pan ,filled the filter 1/2 full and put 10 qts in the pan and then scribed a mark to represent full …
