Mid Range surge
Results 1 to 11 of 11
Mid Range surge
    Member 00 CP's Avatar
    May 2013
    Fallbrook, CA
    Default Mid Range surge
    I'm getting a surge, almost a miss, between 3200 and 3800 rpm.
    The motor is a 508 BBF, 12:1, .715" lift mechanical roller, timing set at 34 total. Rings, bearings, timing set, valve job, lifers and rockers this season, but the bottom end is basically the same combo as last year. What's new is the Trick Flow intake, 1150 Dominator and scoop. 86 (92's from factory) and 102 jets with a 5.5 power valve (factory). I'm thinking the power valve should be a 3.5 (as in the 925cfm carb I replaced) or maybe a 2.5. There aren't any vacuum ports on this carb or manifold. Hoping the experts can help me out here, not sure the PV would even cause this problem. Thanks
    May 2013
    Fallbrook, CA
    Nobody has any ideas?
    Should have mentioned that the ignition is MSD6A box with billet distributor, new cap, rotor, wires, plugs. Motor runs fine at lower RPM's and at WOT.
    Prob 3 circuit dominator carb right? If so it needs some tuning
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Quote Originally Posted by 00 CP View Post
    September 25, 2014
    Hello People
    Save yourself some time:
    C&J Engineering, One time and the problem is solved
    Willis
    031 RIVER4FUN's Avatar
    Bruce, check out the C&J thread. Send it up to John. It'll be perfect when ya get it back. When I bought my 1050s brand new I didn't even open the boxes. Sent them straight to C&J
    May 2013
    Fallbrook, CA
    Default Thanks
    OK, I'm sold. Will be calling John tomorrow.
    Thanks for the advice.
    CP-Carrillo Piston Maker's Avatar
    Apr 2009
    In the Dungeon
    Quote Originally Posted by willis View Post
    September 25, 2014
    Hello People
    Willis
    John says thanks Willis.
    Gardena, CA
    Quote Originally Posted by Piston Maker View Post
    September 25, 2014
    Hello People
    Tell your dad I said hi and are the both of coming to the races?
    Willis
    Apr 2009
    In the Dungeon
    September 25, 2014
    Hello People
    Willis
    I will. I'm unable to attend, but he may....not sure yet. Good luck to everybody though.
    Gardena, CA
    sacramento
    probably lean if it is missing. you want fuel earlier from the power valve not later .try something like a 6.5 or higher, not a 3.5. that holds the fuel back until higher rpm/less vacuum.
