GPS Speedo Antenna
Results 1 to 7 of 7
GPS Speedo Antenna
    Senior Member xxtremez's Avatar
    Jul 2013
    Texas
    Default GPS Speedo Antenna
    Where have you guys mounted your GPS Speedo Antennas? I am looking for a clean or hidden place to put it and still get a good reception. Its on a winger.
    Thanks for any help.
    Fo Show
    Wink
    Shit mount it under the bow its only gta pick up 45mph anyways lol tell your dad hi and i owe him a ride
    Sep 2011
    Los Angeles
    Mine is right behind my driver seat
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Ours is under the dash and has worked fine.
    sacramento
    i found a spot that was out in the open, there was hole there already . i put a bezel around it!
ID:	620577   Click image for larger version.
    Jul 2013
    Texas
    Hell, 40MPH is all I need now. I took that little 100 shot off and started running it on pump gas...
    Fo Show
    under the bow, as long as it's not metal or carbon fibre. pointing it up obviously helps reception.
