1979 witchcraft jetboat - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 22 of 22
  1. #15
    Oct 2014
    78hallett these are the 2 filters that are running about 2 foot on each side from the tanks. then there is fuel lines that run to a T then a line to the pump. Do I even need the filters or should I get something else. Thank you for the help.
    Member 78hallett's Avatar
    Jul 2012
    Norcal
    Like I said, IMO you dont need those filters. Just one good inline filter on the feed line going from the T to the fuel pump.
  4. #17
    Oct 2014
    understood thank you 78hallett.
    Oct 2014
    Does anyone know where I can buy "witchcraft emblems" for the sides of my boat. Not sure what the first owner did with them. Thank you all in advance.
  7. #19
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by witchcraft 1979 View Post
    those little plastic pos filters are fine for lawnmowers. not so good for boats. real nice when they crack, get gas all over the bilge and start the boat on fire...
    if you have tank vents outside the gunnel, they need to be kept clean and clear. you also need to think about a fuel/water separator/filter. something like this
    FUEL/WATER SEPARATOR KIT: Outdoor Sports : Walmart.com
    there are numerous places that have similar separator fittings like this. there are numerous types of spin on filters that also function as separators. some have drains on the bottom of the filter so you can drain water out into the bilge when it's full. you can get spin on replacement filter/separators at napa.
    the thing is, as you run the boat around, those tank vents become water suckers. the more exposed they are to spray, the more water get's into your tanks. with a separator, you don't need a "T" or "Y". you can run hoses from each tank to the separator, then one hose to the fuel pump. works fine. way better than those little pos lawnmower filters.
  8. #20
    Oct 2014
    bp298 where would this thing go at securley. it looks like 4 holes but only 3 hoses. Please give me brief desript. thank you for the help
  9. #21
    Senior Member almost busted's Avatar
    Sep 2012
    MN
    here is one way to set it up if thats what your askin
  10. #22
    Oct 2014
    Default Diverter
    I have a witchcraft 1979 21ft and I was think about putting on a diverter to my panther jet. I am new at this so any responce would be great. Any thing positive or negative. Thank you guys.
