Place diverter bolt on ride plate
Results 1 to 10 of 10
    Member 78Rogersrunner's Avatar
    Apr 2014
    Default Place diverter bolt on ride plate
    Looking for some one who is running this or has this and would be willing to get a couple measurement for me. If so please message me so I can get some from you. Thanks
    You could give Dwayne at HTP a call and get the bolt on shoe/ride plate. I put one on my hull and works bitchn.
    Made In The Shade
    Custom Window Tinting
    Apr 2014
    Do they fit v-bottom hulls?
    Quote Originally Posted by 78Rogersrunner View Post
    yes
    If you have the standard berk intake...yes but contact him. Easy install with bitting edge right at keel. I set my plate at 3* up from keel. You also might have to shave the small part of your hull if its v in between intake an trans if yours isn't set back. Used marine epoxy with shoe in and around all areas for a smooth transition. Mention to him on cradle hieght or type of cradle depending on bowl. I had to get a tall cradle from ARS marine cause at the time Duane was out of them. I still ended up using a block wedge to get correct degree. He will send you some thin spacers for fine tuning the plate but if your hull is similar to mine, a block will be needed. I kept my rock grate but had to trim it slightly to fit once shoe was installed. Added right angle to plate for strength an had parts powder coated/polished.
    Made In The Shade
    small block jet 2sangers's Avatar
    Lexington SC
    Krusin, thanks for posting those install pics. I think that will work fine on his Rogers.
    78 , Looks like your photo/attachment and your original question was specifically about a Place Diverter addon rideplate and droop setup , have sold and installed dozens of these , what measurments is it that you need or would help ? Tom
    Apr 2014
    Yes I was about that setup but I a kinda interested in this setup he his talking about. But I was thinking about fabricating my own bolt on similar to that and was wanting to know as much as possible on the measurements as I could
    The Place droop has 1 1/2 drop (more versus many others ) that puts it in closer proximity to the keel and in better position for bolt on plate which dooes help some , you also might want to consider a winter layup project of actually pulling the intake and machining it (or having it machined) for a shoe/rideplate combination , all jet boats can benefit from this ...
    Apr 2014
    Yeah my new race boat will have one the correct one with the intake machined and all but this is for my old one and I just like goofing off with it and seeing how much I speed I can pick up cheaply since it is a raggedy old boat. This year I've gotten 20 bringing my up to 65mph far using a bone stock 350 and spraying with nitrous.
