More Cable Woes!
Results 1 to 13 of 13
More Cable Woes!
    Senior Member JetBoatCop's Avatar
    Elgin, TX
    Default More Cable Woes!
    My the 78 Taylor. Whoever hooked up the steering must have been on crack! When you turn the wheel right, the jet turns left and vise versa. What the hell?? It has to be something about where the cable hooks into the box at the helm. Anyone have any ideas? Thanks
    Eric
    '78 Taylor SS 460 BBF, Under Construction
    '03 Glastron SF 185 18', 4.3 Volvo Penta
    '95 Dodge Cummins 3500 4x4 Single Cab, Dually, Triple Gauges, and some pump work!
    Angier, NC
    Quote Originally Posted by JetBoatCop View Post
    Eric
    flip the rack on the helm
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Newton Ks.
    Yep, I accidentally did this to myself when I replaced my helm setup 4 years ago (bad cable). It's just 4 bolts, leave the wheel and all in place, and flip the rack from top to bottom, or vice versa, as aplicable.
    The test drive was really "interesting", since (I followed the instructions) I didn't actually check opperation before getting it wet. (dumba$$ me)
    Soon as I backed off the trailer and spun her, she spun backwards, and I knew what was up.
    H.L. Mencken
    if its a rack system on a jet the rack goes on top of the helm
    #55
    Silverdale, Washington
    Been there done that...... Could not for the life of me get the hang of it and ended up sideways at the trailer......
    Easy fix Copper
    On a right hand drive yes, assuming the steering cable is ran along the starboard side of the boat.
    However, on a left hand drive where the cable is ran along the port side of the boat the rack should go on bottom.
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    What is the minimum radius you can bend these cables? I am going to have to replace a cable on the boat I am picking up and it has two 90 bends at the back of the boat that just dont seem right to me. I know the boat has the original rigging that it came from Commander with but it just seems too severe to me.
    Joe
    Joe we like "large sweeping" turns of no less than 18 to 24" (9 to 12" radius) These cables will work with tighter bends but cable life will be drastically reduced from cable top jacket "chaffing" . We often find cables routed all the way to the transom for example then across and another tight bend to exit the transon/ steer tube. We try to route the cable to drop out out behind the rear seat and straight back under the motor instead if possible ( again two large sweeping turns)... Tom
    Newton Ks.
    Easy fix Copper
    I/we (admiral & I) drove around for about a half-hour, on a really small lake (Harvey County East Lake, more of a big pond really) before trailering it (was there doing engine break-in anyhow). Small ovals at cruising speed.
    Managed a decent job trailering it.
    Reversed it the next day. LOL
    H.L. Mencken
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    That depends on which side of the boat the helm is located. Left side it gose under the helm, right side on top.
    Wags
    Newton Ks.
    Depends on the drive too. The instructions were backwards is why i screwed it up.
    Helm is on the left.
    MOST jets steering input on left side (like my new Place Diverter).
    My Berk "F" pump, Steering on RIGHT side, so is backwards. This is where it screwed me up, and the instructions did not consider my insert pump.
    I think an "E" steers same as an "F", cables on the right side.
    H.L. Mencken
    my bad, I looked at a Kona jet, I forgot it was a E pump
    my daytona is on the bottom, both routed down port side
    #55
    Newton Ks.
    Well, I still have the suction housing of my "F" pump. LOL
    The rest is changing this winter.
    H.L. Mencken
