Valve Cover Gaskets
Results 1 to 10 of 10
Valve Cover Gaskets
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Default Valve Cover Gaskets
    Hey Guys,
    Can I get a recommendation on some valve cover gaskets? Cork, rubber, steel core what do you guys prefer?
    Shhh!! Can you hear that?? GJ
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    I use the thicker cork gaskets(http://www.summitracing.com/parts/mr...make/chevrolet). I used contact cement to attach them to the valve covers and have put them on and off many, many times over the last 10 years without a leak.
    Mar 2010
    Clarksville, TN
    I like the Fel Pro rubber with steel core.
    Redding, CA
    I use these.
    http://www.summitracing.com/parts/fel-1630
    They don't have locator tabs, but My Brodix heads have long 1/4" studs for locating and brodix cast VC's with machines seal area so it's a piece of cake.
    No sealer or glue, just slip them on and slide the VC on the studs.
    They last a long time even with repeated VC removal. Just don't over tighten them.
    These actually work better on my deal than the metal cored rubber ones that a lot of guys like.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member bc18's Avatar
    I've had good luck with fel-pro 1635
    Santa Clarita,CA
    Thanks Guys
    Diamond Bar, Big River
    If choosing the bonded cork method, which works well with a good, flat v-cover flange, add a light coating of white lithium grease to the cork gasket before installation and you will be good to go for removals as necessary down the road.
    Quote Originally Posted by GottaJet View Post
    Hey Guys,
    The ones that I find to be the best are a grey silicone material with a steel core, from ROL. A little more money, but you will be able to pull valve covers as often as you want. Also, no gluing or sealing necessary. The look like the ones GM sells, but not at the GM price.
    X 2 Blue rubber steel core
    Tacoma Wa
    Ive got some rubber with steel core that came with the boat. No clue how old they are but they seal great. I opted for cork on my wifes AMC as the valve cover wont be on and off. No leaks yet.
