Timing 472 BBF
Results 1 to 8 of 8
Timing 472 BBF
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Default Timing 472 BBF
    I need to set the timing on a pretty mild 472 BBF Pertronix RTR Billet marine dist.
    I'm hearing 35-38 set at 3k what do you guys recommend?
    Shhh!! Can you hear that?? GJ
    Quote Originally Posted by GottaJet View Post
    What compression ratio, what altitude , more info the better ...
    Santa Clarita,CA
    Honestly the guy I got the boat from had no info to give. He has just recently given me the name of the guy who built the motor, so I will be touching base with him soon to see what I can get. He said he thinks it has an RV cam in it and some head porting and valve work. As far as altitude the boat is mostly used on the river (Parker) and here in So. Cal at low altitudes. I guess for now a generic baseline would be helpful.
    Senior Member Futs's Avatar
    Orange CA, Big River
    I would start at about 32-34. all the fords I have built and worked on don't like a lot of timing.
    Dealing with an unknown (compression and cam) your best to error on the side of caution and time it like Futs suggested for now , is the Petronix a conversion on the OEM Pretolite distributor ? or an actual new unit ?
    Santa Clarita,CA
    Thanks Guys,
    It's an actual new Pertronix Billet Marine unit not a converted Prestolite.
    Promoting pollution Smog Pump's Avatar
    Sep 2010
    Pumpkin Center, CA
    According to RiverRacer, if it has Iron Heads it will run best between 36-38 degrees. Older Iron heads require more advance than the newer Aluminum varieties w/ heart shaped, fast burn chambers. Talk to your builder, but RiverRacer is pretty sure he'll say 36-38 will be best for performance.
    It don't have to be fast to have fun............
    Santa Clarita,CA
    Quote Originally Posted by Smog Pump View Post
