Diverter stop
Results 1 to 14 of 24
Diverter stop
    El Cajon, CA.
    Default Diverter stop
    Would one of you please post up a close clear pic of a adjustable diverter stop installed on a diverter, I'd like to copy it and use it on my hydraulic diverter, my boat doesn't have a trim gauge. Thanks!
    Rod heres a pic of one off (i belive) Williams boat ... Tom
    let's see more of that mechanical popoff neato, is it a kit?
    El Cajon, CA.
    Thanks Tom. Perfect. William even said to look at the pics of his boat, I guess I don't have that pic???
    I don't know, but I know it's been replaced/upgraded.
    wonder how well it worked, that's the 1st mechanical popoff i've ever seen.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    ot not really a pop off it's a wilder valve supposedly made to work like a clutch
    Quote Originally Posted by 78CoLeBBF View Post
    even cooller seems like it'd be hell on the suction housing if the motor was at 6k and the valve shut
    Golden Shores,AZ
    ask red pearl about them he's got the acurate info on them pretty need for the times
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    there is also a black picklefork (i believe an eliminator, not the one with flames) with mechanical stack injection that has one i saw it at the power tour or it was on memorial day... pretty trick setup though!
    "i'm into snatchin' kisses... and vice-versa!" haha
    Golden Shores,AZ
    yup
    El Cajon, Ca.
    I have one on my crusader... they really don't work all that great as far as being a safety relief valve... especially when you nail the valve springs down as tight as you can so it doesn't open "automatically"... but they do "help" a little bit... you can kinda feel the boat settle a bit when you mash the pedal.
    The Bostick®
    El Cajon, CA.
    Some posts are useless without pictures!
    Quote Originally Posted by 84Condor View Post
ID:	27335   Click image for larger version.
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    I GUES HE SHOWED THAT WACKER WHERE HE BELONGS!!!! JETS OUT FROUNT, AND WACKERS IN THE FISHING TURNEMENTS. LOL
    Senior Member BAE 557's Avatar
    The Wilder popoff worked OK, but the current Miersch setup is much better because of the bigger opening,
    it can disperse more water.
    I got the diverter up/down stop from Frank Place, he said it was of the same design he used on Going Places II.
    Blue Thunder, Mach 1 Project *** Completed ***
    Pax Per Potens
    Semper Fidelis
    No Way As Way
    No Limitation As Limitation
