Carbon Fiber Scoop
Results 1 to 9 of 9
Carbon Fiber Scoop
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    Default Carbon Fiber Scoop
    Looking for a Carbon fiber scoop like this. Does anyone know who makes them. Harwood used to but they are now discontinued.?
    SAMSPARTS.COM
    You could probably hydro dip a std. scoop to look like carbon fiber for a fraction......just a thought
    Senior Member almost busted's Avatar
    Sep 2012
    MN
    that would probly be best !! there will probly be a seam or two in the fabric from all the angles on the scoop . unless you trying to shave some weight . also if you paint some of it and clear the whole thing i bet the weight would be close, Ben there done that for ski doo on there race sleds and it didnt end up much differant in the end to make it worth the cost. JMO
    Senior Member ontheNOS's Avatar
    Jan 2012
    Inland Empire
    I had my scoop wrapped with white
    Carbon fiber. Looks awesome. Although Unlimited Fiberglass here in so cal does make carbon fiber scoops if ordered. They also have silver carbon fiber.
    Call Kevin. +1 (760) 596-2379
    Atlanta TX
    I think Ryan Piazza found this one new on ebay........seems like he did say they were discontinued though.
Name:	carbon fiber scoop.jpg
    Sep 2009
    Walled Lake, Michigan
    Default carbon scoop
    Rob Ward makes carbon products. Although not exactly like the one you posted. Rob makes 2 or 3 styles of scoops. I am just mentioning this as an option. He is near London, Ontario Canada. I will likely be going to see him before the end of the year. I could bring something back if you would like. (I see you are in Michigan). Rob might be interested in making something custom? Although he does this as a side job and is usually pretty busy with his normal products. It wouldn't hurt to ask him? He posts on here as FastForward, his is one of my friends in my profile if that helps. He has photos in his profile. Also search on here and there is quite a bit of his stuff around. I see it comes up used on here every so often.
    Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    Apr 2009
    se michigan
    Thank's for all the feedback, I'm persuing a couple of the options.
    SAMSPARTS.COM
    Oct 2014
    I have one I might sell for the right price
