Tahiti Jet boats
Results 1 to 14 of 26
Tahiti Jet boats
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Tahiti Jet boats
    Buddy has one, it has really short/skinny gunnels. THe boat came with a bow mount fuel tank but he wants to put saddles in it. Curious if any of you guys with these boats were able to put 8" round tanks in them or if you had to go rectangle. Pics please!
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I'll be interested to see the answers as well, since I have a 16' 6" Tahiti with a loose bow tank that I'm going to remove and replace with some sort of saddle tanks.
    Wags
    two strokes is enough
    Yuma, Az
    if its at all possible i would definately go with round saddle tanks cause i have the rectangle tanks in mine and it would cost a chit load to switch to the better looking saddle tanks plus mine look like crap its a good thing i have panels to cover them up
    Sacramento, CA, USA
    Where can you find some nice round tanks in about the 10 gal each range?
    Wags
    Senior Member tahitijet's Avatar
    i know in mine i would not be able to fit round at about 10 gal.. maybee 7gal.. my tanks are shapped to fit the floor and side of the boat and they go all the way from the front gunnel support to about 10" short of the transom. and are 11 gallon each. the interior side panels cover them though so you can't see them.
    Sacramento, CA, USA
    Quote Originally Posted by tahitijet View Post
    How about a photo of what you have?
    Wags
    San Clemente, Ca
    All of these boats i've seen have the rectangle shaped to the boat takes or the bow tank. I was curious if anybody had installed round tanks in theres. The problem i see is with lining up the fuel fill otherwise it would mount like any other boat....
    El Cajon, CA.
    I don't have a Tahiti but on mine they just turned the tank until it lined up (more or less) with the fill.
    Sacramento, CA, USA
    Well, in my case there isn't a fuel fill to line up with since the original tank was in the bow.
    Wags
    Anaheim/BHC- the Shack
    My old 1976 18' Tiger had twin 8" Moon saddle tanks.
    Sacramento, CA, USA
    Too bad you can't find them now.
    Wags
    Senior Member R/C-PILOT's Avatar
    Sugar Grove, Illinois
    My Tahiti is 15'11", I don't know that measurements from mine would help you. Mine has 12 gallon rectangular's. I would think taking a new set to a good welder could make them work, then have them polished afterwards.
    R/C
    NRA Life Member...
    Sacramento, CA, USA
    I can get a set of the regular trianglular type saddle tanks that are made of aluminum, 48" long, I guess I could make those work.
    Wags
    How do you mount a round tank other than through the bottom of the boat???? My tahiti also had non round tanks.
