What makes a Hardin Marine engine any different than an Automotive engine?
Results 1 to 11 of 11
    Las Vegas, Nv
    Default What makes a Hardin Marine engine any different than an Automotive engine?
    Just a curious thought, But what makes a Hardin marine engine any different than a car or truck engine.
    Talking mainly about a 80's to 90's 454 bbc. Out of curiosity i was searching for specs on the Hardin Marine engies and cant really seem to find any thing on internals, bearing clearances, marine coatings and such.
    I did find one post, i think on here, and i think by Oldrigger, that said that Hardin Marine didnt actually build engines, but rather baught long blocks from the manufacturer and just bolted their accessories on.
    If this is the case, are there actually any differance in things like bearing clearances, from an automotive engine?
    Inquireing minds want to know!
    Last edited by holorinhal; 10-27-2014 at 08:23 PM. Reason: wrong section please delete
    Discovery Bay, CA
    Why don't you give the guys at CP Performance a call (distributor for Hardin Marine) - they'll give you straight answers.
    Las Vegas, Nv
    Dang it, wrong section. i meant to post it in the dyno section.
    Member rick1964's Avatar
    Aug 2013
    San Diego Ca
    I have a 454 BBC in my Schuster and asked the same question a few years back. I wish I could give you a link but I can't remember where I posted it. I probably posted it here. I do remember that I was told it's just a BBC that has been outfitted with Hardin Marine peripherals, such as my valve covers are Hardin Marine, ect. I think that's all there is to it.
    Las Vegas, Nv
    Quote Originally Posted by rick1964 View Post
    Yes, I saw your thread on it. I think that is where i saw Oldrigger, say that they just baught the long blocks and bolted stuff to it.
    Which makes me wonder it there are any diffrences in bearing clearances?
    Las Vegas, Nv
    Well i guess the answer is really not much!
    I looked up the block casting numbers( 10069286) and is said to be a 90-91 Mk IV,4 bolt block.
    I poped the pan to have a peak at the inside and was pleasantly surrprised to find a pretty clean inside.
    While i was there, i decided to pull a main cap to have a look at bearing condition and decided to do a quick Plastigauge bearing check.
    The results were not what i wanted, but did tell me that there is really no differance in a stock Hardin marine engine and a regular ole truck engine.
    The main clearance measured out somewhere between .0015 and .002, which is pretty much stock automotive clearances.
    it does have a windage tray and a deep sump pan with a trap door, which i did like seeing. but thats about it. nothing special
    corona calif
    Default 454
    Brass freeze plugs and at times a cam change other than that they are the same.
    Jul 2013
    In addition to windage trays, better baffles in the front sump pans, cam changes and such, ANY lake cooled automotive style V-8 HAS to have more piston to wall clearance because of the block being colder than in an over-the-road application meaning that the bore is smaller at the colder temps. You can't use automotive clearances (for very long any way).
    Rob
    Las Vegas, Nv
    Quote Originally Posted by White Lightning View Post
    Rob
    Yes it does have a windage tray and the stock looking truck pan does have a trap door in the sump.
    Rob
    Ideally you may be correct, but I'd venture to say there are many boat engines that have run a long time with a basically stock automotive engine.
    Long Beach
    You're absolutely correct, there's tens of thousands of stock auto engines pushing a pump and they'll last a lifetime if taken care of and left basically stock.
    Decades ago one of the boat mags did a test of 'stock' marine engines used in the biz. Not only were they bone stock factory engines, with the exceptions listed by others above...brass plugs, truck oil pans (maybe), the high performance engines offered were very disappointing. Mis-matched pistons, some questionable cams and so on. The only real thing that was high performance except for the stuff instantly identifiable like intake manifold and carb change was the stickers on the valve covers saying it was the 'high HP model'.
