[Question] Impeller designer/ silent propulsion/ looking for some guidance
    Oct 2014
    Hamilton, Ontario, Canada
    Default Impeller designer/ silent propulsion/ looking for some guidance
    Hi,
    New to the board. I'm the CTO of a company called enevor, that is built around a bunch of patents I own on an impeller.
    35 years ago, when it was just a concept, it was supposed to be a silent propeller for marine propulsion. I sort of ended up in fluid mixing about 30 years ago.
    Recent work on my impeller, the stuff you can do with SolidWorks and a 3D printer, I solved some issues with my initial propulsion concept. (Yes, I have another patent).
    Early is ugly, so bear with me. The impeller is silent. Has a basically acoustical neutral signature. Thought was, maybe a fishing trolling device?
    The impeller you see in this video is using a device that mathematically produces a thrust of about 0.005 lbs. Basically zero, but it is displacing differently. The thing moves along by creating fluid flow, sort of a conical helix. It uses this to move fluid. The fluid moves the fluid, so to speak.
    I have been getting some good feedback from a few people and some military contractor types. Have a look.
    I'm looking to develop this. Look for a team, a network, etc. Any feedback. Like I said, the focus is silent, but looks like we have some speed here.
    Silent Marine Propulsion
    Cheers
    Carl
    Default Welcome
    Welcome to the PB boards
    Sep 2008
    Rancho Cucamonger, CA
    interesting. looks kindof like a water aerofoil or whatever an air wing in water would be.
    why dont you mount it on the front as a puller and direct that thrust over some control surfaces, would probably make some crazy maneuvers possible.
    in a surface running configuration like in the video, it makes alot of bubbles and bubbles aren't silent.
    why do you call it silent propulsion?
    Sep 2008
    i must have completely missed it. hey, i'm a simple guy cut me some slack!
