Oil Drain Plug
Results 1 to 11 of 11
Oil Drain Plug
    Senior Member JetBoatCop's Avatar
    Elgin, TX
    Default Oil Drain Plug
    Do they make a drain plug for a BBF that has a valve that you can hook a rubber hose or something to, to drain the oil? I don't wanna have to hassle with a pump and all that stuff. Thanks
    '78 Taylor SS 460 BBF, Under Construction
    '03 Glastron SF 185 18', 4.3 Volvo Penta
    '95 Dodge Cummins 3500 4x4 Single Cab, Dually, Triple Gauges, and some pump work!
    Senior Member JDG911's Avatar
    MESA
    chevy or ford i had a fiiting welded to my pan with a pressed copper fitting on that with a ruber hose and a brass cap on the other end so i can pull it through my transom hole and drain it that way it always stays on the motor just coil the hose under the motor till you need it.
    Look here:
    http://www.rexmar.com/page273.html
    I have the hose one, but I still warm up the oil and pump it out by attaching the pump to the hose.
    Sleeper CP
    Big Inch Ford Lover
    MESA
    Same Deal Mines Just Welded Never Have To Worry About Coming Loose
    The drain bungs on my pain are 1/2" pipe thread....made that way by Canton. Just a few basic pipe fittings and some hose along with a ball valve and she's good to go.
    Senior Member gregb's Avatar
    Redondo
    I have one of these, I used to use the thing with the hose already attached but wanted to clean up the bilge some.
    http://www.fumotousa.com/
    Look at the N-series, I believe that's what you are looking for, got mine off flea bay for about 20 bucks..
    Elgin, TX
    That's the same one I have on my truck. Thanks for the replys! Tom, you have a PM!
    Eric
    lol, right..... Devilman's Avatar
    South Texas
    Made a drain set-up like this for mine as well, works great & drains quickly without makin a mess.
    Banne'd Cobra1's Avatar
    I want that on my Chevy. It gets old swabbing up the crap that gets in the cross member.
    Bakersfield
    Look here:
    Sleeper CP
    Big Inch Ford Lover
    Sleeper-
    Does the pump get all the old oil out of the pan? How do I know which size to get if I get the plug and hose setup?
    Thanks!
    Skip
    The Earth
    Blog Entries
    24
    The thread on the fittings is 1/2-20 which is standard automotive drain plug thread on most domestic stock pans. Metric threads also available.
    For pipe threads you can take a brass 1/2 NPT to 1/8 NPT reducer and drill and tap to 1/2-20, easy deal.
