How long are berkeley packing rings cut?
Results 1 to 10 of 10
    Member rick1964's Avatar
    Aug 2013
    San Diego Ca
    Default How long are berkeley packing rings cut?
    I bought a good length of graphite packing rope to use on my Berkeley. How long do I cut each rope?
    I've probed the internet but the answer is not forth coming.
    Jun 2014
    can you not just roll it around and check the length or pull an old packing and use it as your guide
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Quote Originally Posted by rick1964 View Post
    Hello People
    6"
    That's the standard length
    Willis
    Aug 2013
    San Diego Ca
    Quote Originally Posted by willis View Post
    Hello People
    6"
    Willis
    Thanks.
    That's what I came up with too 6" .. problem solved....
    While you have them out drill an tap for a zerk...Keeps them lubed.
    Made In The Shade
    Custom Window Tinting
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    I seriously doubt that pumping grease into a zerk at that location is going to do anything to lube packing where it is needed(between the packing and the shaft). I could be wrong though...
    Aug 2013
    San Diego Ca
    Quote Originally Posted by Heatseeker View Post
    That's been my experience as well. I did drill a hole into the housing and installed a Zerk and tried greasing it. Doesn't get to the shaft unless there's a lantern ring. I actually did make a lantern ring, but I'm still not going to use grease, it's too thick to travel between the shaft and packing rings. My whole problem is that since I'm using the boat in a static mode to pump water for a jet pack project, there is no pressure built up from a moving boat, to force water into the packing for lube and cooling. Instead I'm going to push screened water from the engine cooling line, into the pump via a fitting I installed where the Zerk was and lantern ring between the packings. Should keep them lubed and keep air out, replaced with water.
    This is the link to my thread here about this problem I've been having and think I have solved finally.
    http://www.performanceboats.com/jet-...-question.html
    I put a light amount in mine every 3 trips or so and no water in hull...seems to be just fine in my pump.
    Made In The Shade
    Senior Member Keithwidney's Avatar
    Apr 2013
    What should the thickness of the rope be
    Iuka, Mississippi 38852
    5/16 7.9 mm
