fiberglass scoop mounts
Results 1 to 14 of 24
    Senior Member Factory502's Avatar
    Default fiberglass scoop mounts
    I am switching from a stainless scoop to a fiberglass scoop. I am trying to get some ideas for building a base plate- any pics or insight would be greatly appreciated
    Lenord's Custom Fabrication in Fullerton Ca. did mine for a dart tunnel ram and it came out really nice. I dont have any pictures but here is his phone number.
    Lenord's custom fabrication
    (714)526-7930
    Quote Originally Posted by Factory502 View Post
    Kevin at Canyon Boats has fiberglass baseplates.His number is 209-518-7575
    GROSE RACING INC.
    JOEY GROSE
    Senior Member wajetboy's Avatar
    Auburn, WA
    tuffpaw did mine turned out great
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Anaheim Hills
    Default Goza
    Made to fit Harwood..
    I went with this set up:
    http://www.jegs.com/p/Goza/748407/10002/-1
    Anza, CA - Lost Lake, CA
    The TR Harwood base in the avatar is from Dooley, in Anaheim. Fits perfect and works great. The single 4V Dommie base is from Goza Racing, and available from Jegs. Fits the same Harwood scoop.
    RR
    Senior Member bobbo541's Avatar
    San Ramon, Ca
    Quote Originally Posted by GROSERACING View Post
    yah but he probably wont answer
    San Ramon, Ca
    these guys will have what you need.http://www.swracecars.com
    Thanks for all the input, I am going to attempt to build my own, but if all else fails, I will buy one- do you guys have to remove your base plates to adjust float levels, or are there holes in the plates to access them???
    Glendale Arizona
    Mine is home made. Sorry........it's a little dirty. It has to come off to
    adjust float levels, but how often do you have to readjust those?
    You can make jet changes without having to remove it, so that's kinda
    nice. These carbs are mounted side saddle though. If they were inline
    you'd have to pull the carb to make a jet change.
    I like this one from Carnivalrides tunnel ram.
    #55
    Senior Member JDG911's Avatar
    MESA
    what set up do you have. i have the holleys sitting side ways. i had a new one built so my old one could be let go let me know
    Bullhead City, AZ
    Here is mine;
    Abbottcraft Scoop & Intake Elbows Base
    http://www.v-driveboat.com/vweb/showthread.php?t=1122
    Scoop Base prep !
    I got the scoop base/tray from Aaron at Intake Elbows. I designed it and he turned it into reality. It is nice and thick with 4 tubes that connect to the carb base studs. So it should be strong enough to handle the riggers of circle racing. As you can see from the pics attached it is a stout unit. The problem for me was it was kind of plain. So I desided to polish it. I started with 220 sand paper smoothing out any and all protrusions. Then I smoothed the grain with 320 and worked my way all the way up to 2000. I washed with Dawn soap and then dried it. Now the real fun begain. I think I spent 4-7 hrs with NeverDull. It could use a bit more polishing, but I am done for now.
    Scoop prep !
    OK being I killed most of the day helping Tony finish up his yard, I desided to get as much done on the scoop as possible. The scoop is a Abbout Craft and the base is from Intake Elbows. I sanded the white gel to accept the metalic silver base. Once that was dry I wet sanded it with 400 and put the Cordova Brown on. It ook 3 coats to get even coloring. Then I wet sanded it again with 400. Cleaned it well. I then began striping it with gold leaf pinstriping tape. I laid the clear on thick, as I will have to wet sand it again with 600+ to have the look I am looking for. I have posted some pics of the scoop and the polished base.
    Thank you Mike and Aaron !!!
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Quote Originally Posted by Squirtin Thunder View Post
    Here is mine;
    Scoop Base prep !
    Scoop prep !
    maybe I'm blind???
    #55
