berkeley jet questions
Results 1 to 3 of 3
    Nov 2014
    Default berkeley jet questions
    I'm looking to build a "fast" boat in the near future. I got a pump for free and wondering if it is going to suit my needs. I belive it is the JC model. I want to put a droop snoot, place diverted and different prop into it. I know I need a split bowl to do so and the JC is not. Can I put a different bowl on this pump or should I just sell it and start over?
    Quote Originally Posted by chadchad09 View Post
    Good score The pictured jet looks to be a 12 JC (has a C howl) , there should be an ID tag on the suction housing just back of the bearing that would indicate this information as well as production vintage, Its a good foundation for what you want to do and will accept most all mixed flow split bowls from Berkeley A,B,G, Dominator 12 S, some ATs and Aggressors, all of those bowls can be equipped with droops and many other "bolt ons" , most all the listed bowls except the Berkeleys have larger ODs than the C bowl requiring minor mods to Berkeley transom adaptors (if used) Good Luck ..
    Nov 2014
    Pm sent thanks for the info.
