Throttle Cable and Linkages
Results 1 to 12 of 12
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    Default Throttle Cable and Linkages
    Can you guys tell me and/or show me how you guys are running your throttle cables? The boat came with the standard iron manifold and Holley Spreadbore carb but I didnt take off the Carb or linkage and for the life of me I cant figure out which way would be the best way to re-do the deal with my current Performer RPM and Holley DP. The current set up mounts to the Intake bolts but that is too low with the taller manifold. My pedal is also a Push type and my cable is routed to the rear of the boat and then back to the engine. If I had a shorter cable I could just come off of the front of the engine.
    Anyway, photos would be great to give me some ideas of the options available!
    Merry Christmas,
    Joe
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Looky here...
    Carb base mounted adapter.
Name:	'08 boat pictures 021.jpg
ID:	28041   Click image for larger version.
Name:	'08 boat pictures 039.jpg
ID:	28042   Click image for larger version.
Name:	'08 boat pictures 055.jpg
ID:	28043   Click image for larger version.
Name:	Boat for sale 020.jpg
ID:	28044   Click image for larger version.
Name:	Our boat at Lake Berryessa 101.jpg
    Loose, the Dogs of War!
    Nov 2008
    Arizona
    I think I am just going to have to order a shorter cable because the way you have it is the only way I can see how to do it myself.
    Thanks,
    Joe
    So, route it from the back and push on the lower half of the throttle arm on carb. Not at all uncommon.
    Nov 2008
    Arizona
    I was hoping to see some photos of a set up like that.
    Joe
    How about putting up a pic of the parts you have?
    Just imagine the bracket in the above pics flipped around so that the cable mounts beneath it to the rear of the carb. You can see the hole in the linkage to connect the cable to in those pics, just below the throttle cable mounting plate. It really is very simple!
    Found this pic for you, courtesy of DCM(Donahue Custom Marine)
    Kingman/Golden Vly, Az
    ysss, so "simple", even a cave man can do it!!!! LMAO
    FastRat
    Nov 2008
    Arizona
    OLD SQUIRT, you are correct I should have put photos up. My carb linkage doesnt really have the arm below the throttle shaft but I maybe able to make something to bolt on to make it work. I also have to fab some vent tubes etc. I also have the carb on backwards from what I perceive to be the normal (linkage on odd cylinder side of engine) to see what I could make work.
    Joe
    Thanks for your time,
    Joe
    With that cable bracket, you can always turn the carb around (doesn't care which side is front) , mount the cable bracket at right rear of intake and hook the cable up to the top side of linkage.
    On closer inspection, that appears to be the way you have it mounted already.
    south,tx.
    This will work,mounts under carb or the one pictured above that mounts on top of carb plate works also.
    http://store.summitracing.com/partde...5&autoview=sku
    Nov 2008
    Arizona
    I think I may try to re-locate the holes that hold the cable to the mount to give it an uphill slant to the existing holes on the throttle linkage. If that doesnt work I will go with the base mounts and just turn the fuel inlet around towards the front of the boat.
    Thanks for all of your help. Sometimes your mind freezes and you just need someone elses opinions!
    Joe
