Hey Rexone
Results 1 to 14 of 15
Hey Rexone
    B1 Racing cs19's Avatar
    Default Hey Rexone
    After putting that steering post on a diet it ended up being 2.5 lbs. lighter.
    We drilled some 3/4 and 7/16 pockets into the dash side to get some material out of it.
    B1Racing.net
    415 M3
    So Ca
    CS, I have the same one. Things a F'ing deadley weapon in stock trim. 4.5 lbs on my bathroom scale. I need the thing trimmed down. The lightening holes on the flange are a good idea besides turning it down to something useable. Mabey even flute the thing? Not bashing on the post Rex, alot of material to work with if you want a custom piece.
    Here is a pic of the origional piece. They're nicely made and most of the hard work is already done (boring the center hole) just needed to be lightened a little.
    One more pic of the finished product.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    [QUOTE
    [/QUOTE]
    Nice work cs and Jordan!...hey Jordan, what are you rockin in the reflection?...FILA jumpsuit? Lookin good guy!
    [QUOTE=toddnjuzz;484811]
    LMAO I pulled that pic from the Rex Marine section here on the boards so you would have to ask Rex.
    TRG
    TRG is offline
    [QUOTE=fuelinmyveins82;484815]
    Quote Originally Posted by toddnjuzz View Post
    Probably Brian then! (Bgman)
    Anaheim Hills
    [QUOTE
    Nice work cs and Jordan!...hey Jordan, what are you rockin in the reflection?...FILA jumpsuit? Lookin good guy![/quote]
    Was thinking the same thing!
    looks nice cs and jordan.
    Quote Originally Posted by gunslinger View Post
    The holes didnt do much as far as lightening but it was worth doing, turning the OD down did the trick. Its a bad ass part thats nicely made and unless your picky about weight the part is good as is.
    B1Racing.net
    Senior Member Futs's Avatar
    Orange CA, Big River
    B1 does some top notch work.
    Wanna hit my manifold this week?
    TEN THIRTY ONE RCB19's Avatar
    That's Pulse Pounding
    RCB
    ptz
    ptz is offline
    so ca
    Cool
    you could drill the main shaft out like a machine gun heat shield..
    probably lose a few more ounces..
    Quote Originally Posted by ptz View Post
    Cant take the ID out any bigger, it retains the outside of the calgo column.
    B1Racing.net
    Senior Member HBjet's Avatar
    Looks good you guys...
    ptz
    ptz is offline
    so ca
    Wink
    do it like swiss cheese.,...from the outside.
    perpendicular from the base ,similair to the chopper grips arlen ness sells.
    something like this..
    http://cgi.ebay.com/ebaymotors/_Moto...3A1|240%3A1318
    make the steering shaft out of stainless tubing with a stub for the taper and key way.....polish it and your down town...
    thing would probably start whistle at 90 mph..
    ok .....i've got too much time on my hands...
