Aluminum logs
Results 1 to 8 of 8
Aluminum logs
    punk ass kid warpt71's Avatar
    SYV, CA
    Default Aluminum logs
    I'll ask here, run a gasket and silicone sealer or no gasket!?!? I know opinions are like assholes, but is there an "industry standard"?
    I'll paddle my flat before I drive anything else!
    Depends on block an log... You should be okay with BBC but if BBF , you need the thru bolt log then a gasket. The flange type log on a BBF warp/leak with or without gaskets.
    Made In The Shade
    Custom Window Tinting
    SYV, CA
    BBC and Glenwood style logs
    Senior Member Mohavekid's Avatar
    Penn Valley, The Sierra Foothills
    If the heads and logs are in good shape, no gaskets and no sealer.
    Just snug them up tight, run it to get things good and warm then re-torque.
    You should be good to go for years.
    I'm a high temp silicone guy. A bead around each port, let it sit for 5 minutes or so before you bolt them on and then don't start the boat for 24hrs for a full cure. I gave up on headers gaskets years ago. I've done them like this for 30 years.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Krusn is dead on about bbf logs, I run just gaskets on my Chevy logs
    seattle
    I was told by Jerry Skagen, A boat builder from the '70s, that no aluminum log's ever had gaskets from the factory!! Just High-temp silicone(RTV)...When you use gaskets, it allows the aluminum ears to bend when torqueing the bolts(crushing the gaskets)...
    75 Eliminator
    bullhead city
    especially olds gaskets will warp the manifolds
