Question on changing motor location
Results 1 to 12 of 12
    Oct 2011
    Sandia,Tx. 78383
    Default Question on changing motor location
    Motor is currently 18" from back of block to inside transom . Moving it forward to get 28-30" per Gregs advice. ( approx 1 foot ), Installing longer Stringer motor Rails ( I'd like to be able to just line up new rails where old ones were and re drill new holes in the angle , using existing holes already drilled thru the stringers ) and using same motor plates and brackets . Would engine angle be ok ? Or is there a preferred driveline angle limit ? Most around these parts just say move it , get a new driveline , it's done ?
    PS : 18" measurement is without jetaway . I will be installing one now so new driveline will only need to be about 8" or less
    http://oathkeepers.org
    Crankshaft an pump shaft to be in parallel (=) with the driveline angle around 1-3* basically motor up or down with angle in drive
    Made In The Shade
    Custom Window Tinting
    Mar 2010
    Clarksville, TN
    If your running a Lenco shaft then it will have to be damn near perfect .. A drive shaft with U joints will be alittle me forgiving
    San Diego, CA
Name:	joint life vs angle.jpg
    Boat 405.
    Ralls Precision Machine Ballztech's Avatar
    Mar 2010
    No more than 2* per u-joint, that's what I have been told.
    Oct 2011
    Sandia,Tx. 78383
    Thanks , Nate who's gonna help me do the Jetaway install is a Machinist ...may have to buy lots of "NattyLight" and twist his arm to help with motor rails and placement while we are at it
    Jun 2014
    I would clamp the rails to stringers, ensure they are level side to side and the an
    gle and height you want them on the stringer. Transfer punch the holes with a good tight transfer punch. remove rails and drill tight holes. Reinstall in boat and proceed to mockup engine and placement. Transfer punch the holes for pilliow blocks, mark out lighting holes in rails keeping in ming any acc you plan to mount to rails. Remove drill, slot, polish,anaodize and reinstall. Call friends and pop open beers and enjoy your sucess
    Oct 2011
    Sandia,Tx. 78383
    PS : if anyone is looking for a great place to get motor rail materials ? call these guys !
    https://www.onlinemetals.com/merchan...p=2&top_cat=60
    Quote Originally Posted by Gopher711 View Post
    fyi your link goes to a picture of aluminum angle that is prone to cracking. you want the angle with the rounded inside corner.
    Although the illustration shows a non- radiused inside corner, 6061 is the structural grade with a raduised inside corner. What you want to stay away from is the 6063 angle.
    Online Metals used to have the correct illustration for the 6061.
    Oct 2011
    Sandia,Tx. 78383
    angle is heat-treatable, resistant to stress cracking and non-magnetic.
    6061-T6 Angle features rounded corners and approximately twice the strength of 6063-T52 Angle.
    For what it's worth - (Inside radius angle is often called construction angle, while angle that is basically a right angle on the inside is called architectural angle.)
