where can i get cable extensons for my pump
Results 1 to 13 of 13
    Senior Member rorybsst's Avatar
    Default where can i get cable extensons for my pump
    i recently put an AT bowl/ bowl extension/droopsnoot/and a place diverter.does anyone know where i can find cable extensions or do i need to change the whole cable?
    check your pm
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Quote Originally Posted by rorybsst View Post
    You have your friends boat to look at for a visual just make it like that one.
    Bakersfield
    call Tom @ jet boat performance
    If you dont have any luck elsewhere P.M. me I have one in my garage! M
    Senior Member bead's Avatar
    Default I also have one
    never used it . can ship or if local can pick it up .
    Kingman/Golden Vly, Az
    Hey Mark & bead...
    can u post a pic of what u got??
    FastRat
    Silverdale, Washington
    Quote Originally Posted by Luckie Stiff View Post
    What Skip said.......... Iff'n you're down south, Tommy can hook you up like no other.
    If you're up here in the snow belt, Tony at Skagen Boats will take care of you.........
    Hey Mark & bead...
    FastRat
    Art, I will see if I can get a shot later but mine is the standard slip sleeve style billet aluminum from Berkeley and never used. It is a 6 1/2 extension that came with my Berkeley droop and my morse steering did not need it after a bit of adjust. Mark
    ooppss,think I got the name wrong!!! BURP it's new years eve!!!!!! Burp. Mark
    i dont think 6 1/2 inches is long enough. i need to measure it to see if it is i`ll probably get from u.
    Rory ,per our conversation on "E" and "F" when you move the nozzle back away from the transom with bowls, droops extensions etc will likely require longer cables . On standard C,G Berks and the like, the "anchor point" for the steer cable is at the transom. On the "E" pump the "anchor point is on a bracket attached the nozzle and cable jacket "slips" fore and aft thru the transom seals . To simply extend your cable with a steering extension will aggravate your problem IMO call again if you need help Tom
    thanks for the pics. tom i`ll let u know whats up
