1) What do you guys do for the bowl vents when using a non-marine carb? Can you buy the hooked vents or do you just run a hose between the two vent and punch a few holes over the venturis?
2) I think I have a sinking float in the primary side, if I do, which type of float material would you recommend replacing it with? Brass or the black plastic type?
No marine carb here and no hooked vents either!
Just switched from plastic floats to the brass ones.
No probs at all!
Why do you think you have a sinking float? Are they plastic?
Lets see what everyone else has going on!
Joe "j" tubes are out there for sale in cyber world , won't however make for marine "compliance" if thats what your after. The venting may be a sunk or sinking float , high float level or "nicked/worn/damaged needle valve oring,after mkt N&S, worn/fouled needle and seat, too much fuel pressure etc etc Tom
It was nice talking to you on the phone yesterday. I am not so much looking for compliance as safety. After seeing how much fuel poured out yesterday there is no way I am not going to rig something up to make sure the fuel stays in the carb and not pour all over the engine. I am 99% sure it is a sunk float as everything else is new from a Holley rebuild kit. I am going to take the carb off in a bit to find out. We had a rough night at work last night so I am slow to wake up today!
Those are the two I was refering to. I didnt exactly know what they were made of.
Related Threads
Performance Boats Forum
2.1M posts
41.1K members
Since 2007
