Need wiring schematic
Results 1 to 10 of 10
    Charlotte, NC.
    Default Need wiring schematic
    While i got shit torn apart im going to attempt and fix this spaghatti factory i am looking at under the dash. I came accross the following diagram and answers most of my questions but i was hoping to find one for a fuel level sending unit and how it is wired.
    Thanks!!
    Morgan Hill
    A fuel sending unit is wired exactly like the water and oil p guages, make sure the tanks/senders are grounded well..
    GT
    GT
    Charlotte, NC.
    Bitchin thanks.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    If you have a sending unit on each fuel tank you can wire it to a single fuel gauge by adding a SPDT switch on the dash. That way you can check the level of each tank. I forget what color wire the fuel circuit takes.
    Wags
    Newton Ks.
    Yep, black ground both the tank and the sender (run a jumper from the sender to the tank ground wire, don't trust the fasteners to do it).
    Fuel sender wire is pink color code, from sender to sender post on gauge.
    I installed a capacitive sender 2 years ago and love it, no moving floats, had to add a switched red 12vdc hot/power wire to the sender tho. Auto-detects water contamination as well.
    H.L. Mencken
    Charlotte, NC.
    This is exaclty how it is curently set up.. Flip a switch for left or right....
    So there is a ground for the sending unit and a ground on the tank it self? Did i read that right.. Its all currently set up i just want to make sure i know what i am looking at once i start to pull this apart.
    Sacramento, CA, USA
    What I did was run the ground wire from the sending unit to one of the screws that mounts the sender to the tank and then a wire from that same screw to the enging block ground.
    Wags
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    Where did you get one of those? How was it installed and how much?
    Joe
    Thanks,
    Joe
    1988 Commander BBC454 Berkley JE-A with A-Impeller
    Sacramento, CA, USA
    I got mine from CP Performance and the price depends on your tank depth. 6" - 12" $59.99 all the way up to 49" - 60" for $103.99...
    http://www.cpperformance.com/detail.aspx?ID=65
    Wags
    Newton Ks.
    Quote Originally Posted by SkyHarborCowboy View Post
    Joe
    Centroid Products
    They do Gasoline, Diesel, and Potable Water (for a water tank on a big boat), Can be ordered bent if needed, their max length is 120", and compatible to most gauges ohm-requirements. Min. length is 3"
    Special orders available.
    Fully epoxy potted electronics, 2 year warranty. Mine is nearing 5 years, perfect.
    Installed exactly the same, SAE 5-hole mounting pattern, with addition of one 12vdc switched power suply wire.
    My tank has a tab on it a few inches from the sender, for grounding. I would run a wire to such a tab and bolt it, or, to a mounting bolt, not to the sender screws, but that's just me. IMO better & more consistent contact that way.
    H.L. Mencken
