Needs seats made in or near Modesto, CA
Results 1 to 11 of 11
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default Needs seats made in or near Modesto, CA
    I need to have the passenger bench replaced with a forward facing seat.
    Any recommendation in the Modesto area?
    100 years from now, none of this will matter.
    Just curious does your front passenger seat face center ?
    Mar 2010
    Modesto, Ca.
    Yes.
    78 Hawaiian Click image for larger version.
    Pretty sure this was the style from the factory, even though mine was redone before I got it.
    I want one that matches the driver's side. I know the dash protrudes on that side, but close would be better than what I have. Just a terrible design unless you pull skiers, which I do not.
    Apr 2010
    Rocklin, Calif.
    I believe Lee Wells is around the fresno area
    Mar 2010
    Modesto, Ca.
    Fresno is way too far away. really need someone closer. Thanks anyway.
    Maybe give some thought to different interior Take a hundred lbs + out and go to Glass buckets and rear bench, they way less than 50 lbs without covers , about 80 with covers , the wont rot and the shells are virtually indestructible
    Mar 2010
    Modesto, Ca.
    That would work too, but I still need someone to build it.
    I just don't have the time or the know how.
    I want a pro job.
    My entire interior weighs under 50-60lbs.
    It's all very light.
    Apr 2010
    Rocklin, Calif.
    Check with Steve, he goes by S&S on the boards here, he had a guy in Orangeville do his Rodgers...Super Nice!
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    They really are not that tough to build if you could find a little time. I did mine in one day. The upholstery is the hard/expensive part.
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Quote Originally Posted by jet460 View Post
    Call Jeff Glow at Smooth As Glass in Riverbank and see if he can help or recommend someone.
    Jeff is a wizard when it comes to fiber glass and gel coat repair. He is pretty good with wood repairs as well.
    You could also call Adam at Color Glo Upholstery. He is in Modesto. They did the upholstery in my Hallett over 7 years ago. They are top notch.
    I don't have their contact info handy but you can do a google search.
    Good luck.
    Hallett Dave
    Jeff Glow
    SAG
    Address: 2808 Patterson Road, Riverbank, CA 95367
    Phone209) 869-3545
    Im non induced and My turd leaves pretty hard as she sits.
    Mar 2010
    Modesto, Ca.
    Quote Originally Posted by Hallett Dave View Post
    Good luck.
    Hallett Dave
    Jeff Glow
    SAG
    Phone209) 869-3545
    Thanks.
