BBC454 Jetting Specs with Log and 800DP
Results 1 to 14 of 29
    Senior Member SkyHarborCowboy's Avatar
    Nov 2008
    Arizona
    Default BBC454 Jetting Specs with Log and 800DP
    I need some baseline jetting specs for a 325 HP with Performer Intake, Holley 800DP and Log exhaust. The engine runs good but it is way rich. I got the carb from a friends race car and for the life of me forgot to look at the jets after the rebuild. Anyway, if someone can give me ball park settings (primary and secondary jets, nozzles and power valve) I can take it from there. The float level is perfect so that isnt an issue.
    Joe
    Thanks,
    Joe
    1988 Commander BBC454 Berkley JE-A with A-Impeller
    Nov 2008
    Arizona
    I should add that I dont know the idle vacuum as I dont have a gauge but the rest of the motor other then the intake and carb are bone stock!
    Thanks,
    Joe
    Thanks,
    Joe
    El Cajon, CA.
    Start with the stock jet size and go from there. The stock jet size can be found at mortec.com using the list number.
    X-2 But keep in mind that fat is safe! I would go 86 pri-88 sec and then play. If it is an old school 4781 then should be fine. Always remeber that plugs are cheaper than pistons. No offense hotrodM
    Nov 2008
    Arizona
    Mortec.com says:
    The list number is 4780 800CFM
    (F)72,(R)76 6.5,8.5 4150
    It doesnt mention what squirters are supposed to be there.
    Joe
    Thanks,
    Joe
    Shell Knob, MO
    On that stock 325 hp motor, you might do yourself a favor by putting on a good 650 or 700 cfm and solve the problem.
    Monroe, WA
    I'm running a 750HP on my stock Olds. It has 72/84 for jets. It runs up to around 4500 rpm on the primaries and in cold weather was popping a little bit. Then once the secondaries open it's really fat. I'm going to try going up in the front and down in the back. I was running an 800 with 76/82 in it with no problems but the plugs were black! I'm thinking of square jetting it 74-76, but I'm most likely running in much cooler temps than you are.
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    Nov 2008
    Arizona
    Duane,
    There are no problems. I simply asked for some baseline jetting sizes to get me into the ball park jetting wise. The carb came off of a small block race car and I honestly either forgot the jets that arre in there and/or I never looked at them!
    Joe
    Thanks,
    Joe
    Newton Ks.
    My 700cfm'er was stock with 66 front, 76 rear, 6.5" front power valve, and was quite happy even after the intake manifold and cam were changed (was likely a tad fat to start with).
    Went up to 67/77 when the headers went on, the head porting it stayed the same, and is happy. 69/79 was too much.
    If only your 800 was a tad bigger, i'd consider offering a swap. LOL.
    Kinda looking 850 tho since I am cranking a lot more RPM on nitrous tho than i used to.
    H.L. Mencken
    member
    Nov 2008
    Start around 74 all the way around. Get a power valve block off plug square the jets up and rock out. In my personal opinion squirt boats and power valves are not the best combo. JMO
    El Cajon, CA.
    ... No offense hotrodM
    None taken. The only reason I replied in the first place is because he wasn't getting much response, so I figured I'd put my .01 in and THEN he'd get some response!
    El Cajon, CA.
    Quote Originally Posted by SkyHarborCowboy View Post
    Mortec.com says:
    Joe
    The 850 comes with 31 squirters, I believe. Fat is where it's at.
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Correct I have 31 squirters in my 850 double pumpers. primary secondary jets BIG.
    Nov 2008
    Arizona
    LOL,
    I like how this goes, I specifically state I have an 800DP and half of you want to talk about the 850DP I dont have.
    Joe
    Thanks,
    Joe
